09 February, 2025, 09:57:31 PM *
Pages: 1 ... 5 6 7 8 9 [10]   Go Down
Author Topic: I finally have a Fulvia!  (Read 58820 times)
nthomas1
« Reply #135 on: 29 August, 2023, 08:46:10 PM »
I used these putty strips from Woolies - rolled them out to an appropriate thickness and applied them to the boot opening.   I think they are labelled as body caulking on the Woolies website.
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
IanC
« Reply #136 on: 30 August, 2023, 06:01:56 AM »
Thank you all, it shows our thinking is aligned in that we believe we should put something in there.  Although I have to say I’m still quite amazed at the condition on the lip in the boot floor.
IanC
« Reply #137 on: 30 August, 2023, 07:48:27 AM »
I have finished the rebuild of the master cylinder and am about to refit it.  With the seal kit came a new cap for the reservoir.  When you compare old and new it’s obvious the old one is quite tired so the new one should be fitted.  But the new one doesn’t have a vent hole, whereas the old does.  I can see a reason for both versions, but think it should be vented.  Any thoughts either way on this?  Thank you
Wangler
« Reply #138 on: 30 August, 2023, 08:33:28 AM »
The way I see it is that a closed system might cause a problem, whereas a very small vent in the cap is tried and tested over decades. The enemy of brake fluid and indeed the whole system is moisture, as most brake fluids are hygroscopic. That said, there have been some developments for certain DOT rated fluids that greatly reduce this issue.
Fulvia Coupe 1976
Fulvia Coupe 3 1975
« Reply #139 on: 31 August, 2023, 08:26:27 AM »
As I said there is no part number for the cam alone. I think the allen keyway may be to assist installation. If you try to remove (pull out) in situ there is a shim washer under the worm drive that could fall off into the engine.
Thank you again for clarifying.  I received an original Lancia drawing from Robert with useful dimensions relating to the actuator and its engagement with the pump.  The drawing suggests that if you are struggling to achieve the dimension then you should machine the spacer to suit.  I’m going to give this a go as it was my original thought and clearly something the factory allowed.  I’m still not clear on why this issue exists because the cam face does bot look work.  All I need to do now is work out how much to reduce it by.
This came up on ebay.it.... Nice cam on end....
https://www.ebay.co.uk/itm/325351634564?hash=item4bc077f684:g:MAQAAOSwpdJjKyyn&amdata=enc%3AAQAIAAAA4ID%2FunYbO3kU1vi9TP%2BlzEuAosVA9uLAjtEr8fvEayUhRdwLdYBrJbA5TxswwI2qVwoxyeyjrXOdHWaOEzP3UnL5D1fKtLexXG8KdXUxbMRgSusEUa3IYNFZjUvygQ%2BxD0Fs87ynCdttXsrLWsSbHV%2BxmfRzVUk7dopOZyWaIDbf3geWNp%2BD6drPOymFY2AzXjNv6dT0pVslhzCw7eqBymBIJ4hjiw%2BeL%2FKXqjyCE0QpEmvmNyPpp03%2FQZGvGpRdA8Ea4hepsmHtc%2FbzLxGDD9fnAIBy0ZuZ10xL6xnVrHWo%7Ctkp%3ABFBM3o6Lq8li
IanC
« Reply #140 on: 31 August, 2023, 08:25:19 PM »
Thank you for this but it says Series 3 and mine is a 2.  No idea of what the differences are if any..
IanC
« Reply #141 on: 31 August, 2023, 08:27:11 PM »
Thank you, I agree so will be making a small hole as per the original.
« Reply #142 on: 31 August, 2023, 08:36:22 PM »
No difference
IanC
« Reply #143 on: 06 September, 2023, 10:46:41 AM »
I fitted the new fuel tank yesterday, which was another good step toward getting the car running.  When I say 'fitted' it’s not quite correct as I could only get six of the ten bolts to line up.  I recall mention in a previous discussion about this issue so guess it’s not unusual, although it feels a bit off paying over £600 for something that doesn't fit…….
IanC
« Reply #144 on: 06 September, 2023, 11:53:46 AM »
I guess a little getting with a rotary burr will enlarge the holes in the right direction, which leads me on t9 the next challenge.  I think I’m in the middle of giving up on the mechanical fuel pump due to this anomaly with the actuator.  A few of you have recommended just going to an electric pump such as a Facet.  There is a Red Top kit supplied by Tanc Barrett which seems to be configured for the Fulvia and doesn’t need a pressure regulator.  Seems like a good fit.  Now, I’m not a bad engineer, quite practical, but have always been defeated or befuddled by electrics so the big question is, how easy would it be for me to wire this in?  Also, where have all of you fitted them, is there a standard place?  Grateful again for any thoughts, instructions,photographs, diagrams etc etc
Thank you
Wangler
« Reply #145 on: 07 September, 2023, 08:14:28 AM »
Thank you
On Page 2 of this thread there's a photo of a typical mounting position. Some people like to mount them under the car near the fuel tank, but I like to put things where I can keep an eye on them, so mine is pretty well in the same position as the one in the photo.
Regarding wiring, obviously it should be via the ignition feed, but I would use a relay with an in-line fuse. I would take the feed for the relay from the fusebox (can't remember which one but it's fuse no. 8 or 9 - just use a cheap circuit tester to determine which one). The "outlets" are on the top of the fusebox.
Oops, sorry - correction!  I didn't use a relay on mine. I took the feed from the lower terminal (the unfused side) then added an inline fuse - no relay used.
« Last Edit: 07 September, 2023, 09:05:41 AM by Wangler » Logged
Fulvia Coupe 1976
Fulvia Coupe 3 1975
« Reply #146 on: 07 September, 2023, 08:40:21 AM »
I fitted mine in the boot too it hides behind the plastic trim (but mine is a Sport so different trim configuration?).
IanC
« Reply #147 on: 02 October, 2023, 12:43:16 PM »
Thank you, I had completely forgotten about that picture.  I’m glad someone is paying attention!
[/quote]
Pages: 1 ... 5 6 7 8 9 [10]   Go Up
Page created in 0.083 seconds with 20 queries.
