25 January, 2025, 05:53:36 AM *
Pages: 1 2 3 [4] 5   Go Down
Author Topic: Technical information only  (Read 63361 times)
« Reply #45 on: 13 July, 2013, 02:19:01 PM »
Lancia Blue 1961, Lechler code 121L  (121 is now yellow!)
« Reply #46 on: 11 May, 2014, 01:00:04 PM »
Aprilia rear spring silentblocks  (from elsewhere on the forum)
 Robush Ltd!!!!
Silentblock  18 34 36 32, that is  ID, OD, IL, OL   They have 7 in stock at £4.60+VAT each. I am not sure about postage, especially to France.
I hope that is some help. Their number is 01473 738569.
« Reply #47 on: 08 September, 2014, 04:05:57 PM »
I have used NGK B6S  Ade.
The NGK website  http://ngkntk.co.uk/index.php/downloads/   lists B7S which is a slightly softer plug.   I was having trouble with fouling plugs with B6S so I have changed them.  So far so good.
Zetaman
« Reply #48 on: 17 October, 2014, 10:28:54 PM »
Here is a note, amongst a number that I was given long ago, written by Lancia (England) Ltd.
I shall attempt to write up the others before long.
Paul Mayo
* wsmsteering.doc (23.5 KB - downloaded 438 times.)
Zetaman
« Reply #49 on: 17 October, 2014, 10:32:26 PM »
Here is AST Sketch 22 re-written by me from a poor original:
Subject - Assembly Tolerances & Limits of Wear on Liners, Pistons, Piston Rings & Piston Pins
* Sketch0022-Aprilia.pdf (103.84 KB - downloaded 420 times.)
Zetaman
« Reply #50 on: 17 October, 2014, 10:34:51 PM »
Here is AST Sketch 25 re-written by me, subject "Assembly Tolerances & Limits of Wear for Crankshaft Journals, Main & Big-end Bearings"
Paul Mayo
* Sketch0025-Aprilia.pdf (264.58 KB - downloaded 488 times.)
Zetaman
« Reply #51 on: 17 October, 2014, 10:37:59 PM »
Next one re-written by me on "Valve Gear, Camshaft & Timing Description, Maintenance, Overhaul & Specifications"
Paul Mayo
* Sketch0028-Aprilia.pdf (114.89 KB - downloaded 729 times.)
Zetaman
« Reply #52 on: 17 October, 2014, 10:41:26 PM »
Next one is on "Assembly Tolerances & Limits of Wear on Liners, Pistons, Piston Rings & Piston Pins" for the S1 Tipo 97 engine.
Paul Mayo
* Sketch0036-Aprilia.pdf (103.42 KB - downloaded 375 times.)
Zetaman
« Reply #53 on: 17 October, 2014, 10:46:24 PM »
This one, also rewritten by me is the "LANCIA APRILIA 1st Series - Data & Main Maintenance Instructions"
Paul Mayo
* Sketch0060-Aprilia.pdf (181.04 KB - downloaded 1091 times.)
Zetaman
« Reply #54 on: 17 October, 2014, 10:49:39 PM »
This one covers "LANCIA APRILIA – ARDEA – TIPI 800 - GEARBOX - Locking the Primary & Secondary Shafts",
again re-written by me with additions from other sources.
Paul Mayo
* Sketch0062-Aprilia-Ardea.pdf (335.75 KB - downloaded 413 times.)
Zetaman
« Reply #55 on: 17 October, 2014, 10:58:42 PM »
Here is a list extracted some time ago from my master list of AST Sketches, for the Aprilia.
Paul Mayo
* Sketches-List-Aprilia-Extract.pdf (41.43 KB - downloaded 839 times.)
BlueSky
« Reply #56 on: 22 October, 2014, 11:31:14 PM »
Paul
Only just discovered all the fantastic info you have put on the forum. Wow thank you so much, really appreciate it all, keep them coming.
Noel
Nissan X-Trail T31 TS
1920 P & M 3 1/2hp {FOR SALE}
John Deere LX188
www.narrywoolan.com.au/home
« Reply #57 on: 04 August, 2015, 08:35:54 PM »
Cold Metal Spraying can rebuild corroded blocks and heads and replace broken lugs etc in pretty well any metal.  See my post Fingers (and toes) crossed on Lambda forum.   Nick Gilfillan at http://www.cylinderheads.co.uk/ mobile +44 (0) 7768 622448 is the man to talk to.
« Reply #58 on: 15 November, 2016, 09:49:54 AM »
SETTING TORSION BAR
Measuring from the top of the UJ coupling to the datum line without the transverse spring attatched:
Torsion bar setting on Saloon:
Italian coupling non-greaser = 159 mm
Italian coupling greaser = 155 mm
English/Hardy Spicer coupling = 164 mm
Datum is horizontal line joining shock absorber fixing bolts.
Torsion bar bearing: Lancia 2048307 or 2048056, RIV Tipo 137827 or 5741 – 45 x 78 x 18 mm
Torsion bar bearing currently still available from valter.ferri@ferriadelio.com   I paid Euro 203 for two including VAT and postage.
« Reply #59 on: 29 November, 2017, 04:56:47 PM »
PROP SHAFT CENTRE BEARING
...is the top one on the list.  It is an unconstrained roller bearing presumably to allow compliance with the old type fabric discs.   The housing is a simple split one that fits onto the bearing and requires gentle heat to release it.   There are felt type oil seals either side.   Thank you to Simon for the info. sheet.
Pages: 1 2 3 [4] 5   Go Up
Page created in 0.045 seconds with 21 queries.
