11 April, 2021, 05:06:00 AM *
Author Topic: 1970 Flavia Coupe 2000  (Read 173 times)
msh2908
« on: 04 April, 2021, 05:30:54 PM »
So, in addition to sorting the fuel smell, I'm and planning to change the points, condenser, dizzy cap etc.. They've not been changed since I bought the car 3 years ago. But before I do so, can anyone recommend an electronic ignition alternative?
Any guidance greatly received.
Mark
« Reply #1 on: 05 April, 2021, 07:55:28 AM »
I run a luminition system on the standard distributor on my Flavia Vignale iniezione. Keeps it looking standard.
The only issue I have found with Luminition is the small electronic  box needs to be well earthed to the car chassis.
1967 Flavia Vignale iniezione
1972 1600 Fulvia Sport
1979 2500 Gamma Coupe
1988 Delta 1.6GTi
1998 Zeta
BlueKSO
63 Flavia Coupe
« Reply #2 on: 05 April, 2021, 10:13:04 AM »
Ditto with Tim’s last post.  Have had the Luminition system fitted since I’ve owned my Flavia Coupe.  Makes starting so much better, takes most of the ‘will it won’t it’ out of the procedure.
Cheers,  Peter
msh2908
« Reply #3 on: 05 April, 2021, 11:19:13 AM »
Thanks both for the note on Lumenition system.  Is there a particular model number you are using or they all generic?
Mark
« Reply #4 on: 05 April, 2021, 12:24:12 PM »
Not generic. Give them a call with your distributor model (Marelli 105A??)
1988 Delta 1.6GTi
1998 Zeta
bobhenry999
« Reply #5 on: 05 April, 2021, 02:41:02 PM »
Mark,
I fitted a Pertronix electronic system to my Flavia a few years ago and it has worked perfectly since. Easy starting and smooth running and it’s all contained inside the distributor so no control module to mount/hide.
Bob
Flavia 815 Vignale
Flavia 819 Milleotto
Flavia 815 Coupe Inezione
2000HF x2
2000 Coupe
2000 Sedan x3
Angle Grinder
« Reply #6 on: 05 April, 2021, 04:19:59 PM »
Mark,
Bob
Is it a straightforward thing to install? And roughly how much did it cost?  My Flavia starts on the button and runs smooth but I'm always interested in mods that add modern efficiencies.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
