28 March, 2024, 09:52:53 PM *
Pages: 1 2 3 [4] 5   Go Down
Author Topic: Journey to get Dedra back on the road.....  (Read 28711 times)
HF_Dave
« Reply #45 on: 12 August, 2010, 10:08:56 PM »
The plugs tend to get fouled very easily, My thema suffers from this when I dont drive it for a few days. I find that starting and stopping the engine befor it gets a chance to warm up cause the problem. once in regular use there's no problem Smiley
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
« Reply #46 on: 12 August, 2010, 11:54:08 PM »
Is it soot or oil? if everything is set up ok and you are using the right plugs you shouldn't be having those problems.
HF_Dave
« Reply #47 on: 16 August, 2010, 11:22:12 AM »
I've been using origional equipment plugs in the Thema (I have a box of them ) but i still have this problem every now and then. Smiley Hey Brian I noticed we are nearly twins, David 8228 ! Grin
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
chugga boom
Non-LMC Seller
« Reply #48 on: 16 August, 2010, 12:19:39 PM »
my dedra turbo suffers with plugs fluffing up if i dont let it warm up propperly, if used regurlary its fine if just pulled in and out of unit a few times the plugs need cleaning and it will miss cough splutter backfire THE LOT!! Cheesy and tonnes of black c**p on the floor afterwards, grale was the same
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
toby2449
« Reply #49 on: 18 August, 2010, 03:37:42 PM »
Hi guys, I've gotta remember to run her a bit on a more regular basis, i wouldn't mind i wouldn't actually have to take her out on public road, we have a bit of land so i could do laps!!
HF_Dave
« Reply #50 on: 23 August, 2010, 06:31:29 PM »
Thats all they need, just enough to heat the engine so it's hot enough to come off the cold idle setting. This can cause some debate as to weather you could do more damage by letting the thing run and not get as hot as it would on a proper run ! Huh?
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
toby2449
« Reply #51 on: 03 September, 2010, 10:04:58 AM »
well as its sunny out, i uncovered my Dedra and took her for a wee spin around the house & she felt very good, even the engine sounded good! And all was well........
.....actuallly when i say well i'm not telling the whole story, opened the bonnet to disconnect the battery & noticed something very odd...oil is starting to appear where the spark plugs sit!!! The car runs brilliantly, no misfires now, but where the hell is the oil coming from, & more importantly how do i stop it!!
I started the car again & took a look to see whats happening, as the engine is running i can see the oil bubbles in one of the spark plug chambers, i'm worried now!
« Reply #52 on: 03 September, 2010, 10:49:34 AM »
Mark,
Sounds like the plug might be loose or needs a new seal, see what that does first before going off to look for anything else, are you sure the oil itself isn't coming from the cam cover gasket, as that's the normal source, or spilt oil when topping up which head for the lowest point, the spark plug recess!, and the bubbling maybe nothing more dramatic than the plug is just loose?
neil-yaj396
Committee
« Reply #53 on: 04 September, 2010, 07:41:13 AM »
Definately sounds like a cam box gasket leaking. Before mine was fixed on the Beta I was constantly using a syringe to drain plug recesses 1 & 2. These are the gaskets below the cams unfortunately. Not the easily replaced 'rocker cover' gaskets.
« Reply #54 on: 04 September, 2010, 10:33:34 AM »
Thank rung a bell Neil!,
it was the same gasket that I had leaking that was dropping oil onto the exhaust manifold, and if you're going then it's the ideal time for belt change and decoke.
neil-yaj396
Committee
« Reply #55 on: 05 September, 2010, 07:53:47 AM »
Yes that's the one Brian, if it's leaking at both sides (or both gaskets) oil drops onto the exhaust on one side and into the plug recesses on the other. The oil on the manifold burns of course and makes that awful smell.
« Reply #56 on: 05 September, 2010, 08:33:34 AM »
Neil,
Don't I know it!
toby2449
« Reply #57 on: 05 September, 2010, 03:28:59 PM »
cheers guys, when i get the belts done i'll get new gaskets. Thats not going to be done for a while though - maybe not until next year at this stage! Is there any harm in running the car every so often just to keep her ticking over???
the.cern
« Reply #58 on: 05 September, 2010, 03:44:11 PM »
Hi, I don't know anything about the gasket problem, but I do know that if you run the engine with a loose plug it may loosen further and eventually blow out!! When this happened to me, at 80mph, it stripped the plug threads and caused all sorts of mayhem.
Just nip it up and, I suggest keep the engine in use and deal with the leaking oil as and when necessary.
Good luck,
                 Andy
toby2449
« Reply #59 on: 05 September, 2010, 08:05:48 PM »
ah yes, no worry, as soon as it stops raining i'll be out to tighten the plug, oh & the Dedra is in no state to get to 80mph ( i wish) any running is of a really gentle kind, kid gloves i think they call it! Grin
Pages: 1 2 3 [4] 5   Go Up
Page created in 0.066 seconds with 21 queries.
