Mark,
Don't bother
they were a pain in the backside when new and didn't have a very long service life, the motors are different and not interchangeable from side to side, the water gets into the motors and creates a nice lump of rusty metal.
Another trick (and it happened to me), was when the seperate wash pump motor continued to run until it had drained the whole of the shared wash bottle, and then the pump keep running when dry, the only solution was to pull off the power lead.
The later ones (1993/1994) had the power washers in the bumpers with high pressure jets and were much better, well worth fitting if you can find a set on a scrapper.
The very early ones as fitted to my 1990 2.0iese didn't have the brackets fitted to the top of the headlamps to stop them overriding the top of the headlamps, quite funny bombing down through France in the pouring rain, operating the headlamp wipers and having them waving to me over the top of the bonnet
Best bet is a pair of non wash/wipe headlights, they fit with no problem and your just left with the stainless steel triangles with holes in, and a pair of headlamps you can sell to someone whose headlamp wipers do work.
8227
