26 April, 2024, 08:08:05 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Dedra, Thema and Delta (2nd series)
Delta HPE Starting Problems
Pages: [
1
Go Down
« previous
next »
Author
Topic: Delta HPE Starting Problems (Read 2544 times)
HPEHF
on:
11 November, 2008, 02:00:59 PM »
Can anyone help with a baffling problem with a starting problem.
Whilst the car is cold the majority of the time it starts ok will run fine for first minute or two then cuts out, but re-starts okay. Some times you get a bit of hunting before it cuts out. Some times there can be a small backfire which is probably a buld up of petrol in the exhaust.
When the engine is warm indicated by the oil temperature and not by the water temp which goes up quicker the problem goes away. Oil temp sensor only connected to the guage and not the ECU. ie after 5 mins stop the car and let it sit cures the problem
The car has been on the diagnosis equipment but shows no faults. Both water temperature sensor and mainfold air pressure sensors have been replaced with non original equipment and original equipment to no avail.
As I say it does not always happen on a 2 week trip to Italy, Saturday when leaving it was fine, Sunday & Monday played up Tuesday played up. Then sat for 6 days in Turin. On the return journey it played up on the first three day and was okay on the fourth next to days played up. It then sat in the garage for 2 weeks before being move and was okay.
If the car is left for a day it can play up in the evening.
It has been to the garage several times with no luck in tracing the problem, checked for leaking head gasket, leaking injector seals etc, etc, at the present someone is looking at the ECU
Any ideas on a postcard would be gratefully recieved.
Regards
Simon Davis
8477
Chris5090
Re: Delta HPE Starting Problems
Reply #1 on:
12 November, 2008, 12:07:23 AM »
I could be completely wrong here but i've seen a similar problem,all be it on a Ford (EURGH)! It sounds similar to the problem we had, which turned out to be muck in the Idle Speed Control Valve, the muck makes them stick, but not always. ECU sounds fine to me, they generally work or they don't. I could be completely wrong as i've never seen a Delta HPE but it's one of the things i'd be checking...
Hope this helps - Chris
HPEHF
Reply #2 on:
10 March, 2009, 01:50:52 PM »
Thank you to those who PM'ed me some ideas as to where to look.
I recieved the ECU back last night, and with a spare and another auxillary air valve on stand by started the car after being sat for approx 5 months it started with out any problems and idled until the fan cut in.
The ECU had 1 dry joint, so I am led to believe.
Hopefully will not play up on the trip to Goodwood this weekend.
Regards
Simon
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
