Model Technical and Interest => Flavia => Topic started by: bobhenry999 on 23 March, 2017, 08:59:02 PM
Title: Diesel woes sorted
Post by: bobhenry999 on 23 March, 2017, 08:59:02 PM
Chaps,
I picked the Coupe up this afternoon, and all is now well.
Local garage drained the tank, blew out the fuel line, emptied the float chamber, fitted a new fuel filter and refilled with petrol, and the car runs absolutely fine, so it seems no damage was done.
I brimmed the tank and took it for a blast to clear out any diesel residue from the exhaust and it runs perfectly, in fact it seems to be running better than ever !
Or maybe that`s just a trick of my imagination.
I might look into welding a narrower fuel neck into the tank`s filler to prevent a repeat, providing it`s not too big a job, otherwise I will just have to make sure I engage brain when refuelling in the future !
Anyway, the important thing is it`s not done any harm, so thanks for all your support and advice.
Bob
Title: Re: Diesel woes sorted
Post by: frankxhv773t on 23 March, 2017, 09:12:49 PM
Welding and fuel filler sound a bit frightening in the same sentence. Could you press fit a restrictor into the neck of the existing filler?
Post by: bobhenry999 on 23 March, 2017, 09:20:35 PM
Yes I know what you mean, that is probably a better solution, thanks.
Bob
Post by: DavidLaver on 24 March, 2017, 12:32:58 PM
Surely its the sort of problem you only have the once?
Post by: lancialulu on 24 March, 2017, 01:58:11 PM
Oh to be young David!
