Buy, Sell and Search => Spares required => Topic started by: Andrew1950 on 29 October, 2015, 07:04:26 PM
Title: Wanted: S1 timing chain sprocket (bottom)
Post by: Andrew1950 on 29 October, 2015, 07:04:26 PM
Looking for a good condition S1 Fulvia coupe, bottom timing chain sprocket as soon as possible.  Must be an S1 sprocket as an S2/S3 is different.
Anyone have one lying around? Or, know where I could find one?
Any tips most welcomed & appreciated!
My mechanic has stripped the engine and discovered the sprocket cogs are worn. Need it immediately.
Hopefully, some kind soul can assist.
Many thanks
07570 616570
Title: Re: Wanted: S1 timing chain sprocket (bottom)
Post by: Parisien on 29 October, 2015, 07:11:41 PM
This?
http://www.ebay.it/itm/Lancia-Fulvia-Coupe-Rallye-HF-Catena-Distribuzione-e-pulegge-Motore-818-140-/291578818735?hash=item43e373b0af:g:dE8AAOSwjVVV4y3Q
P
Post by: Parisien on 29 October, 2015, 07:15:29 PM
http://www.ebay.it/itm/Lancia-Fulvia-818-1-Serie-INGRANAGGIO-DISTRIBUZIONE-ALBERO-A-CAMMES-82189883-/251895747601?hash=item3aa6281411:g:3VoAAOSwBLlVFmt2
Or?
P
Post by: Parisien on 29 October, 2015, 07:17:55 PM
http://www.ebay.it/itm/Ingranaggio-Lancia-Fulvia-/191224052508?hash=item2c85d77b1c:g:-woAAOxyOalTZUze
Just running through what it seems like to me?
P
Post by: Parisien on 29 October, 2015, 07:19:16 PM
http://www.ebay.it/itm/LANCIA-FULVIA-INGRANAGGIO-DISTRIBUZIONE-82274860-/261398439392?hash=item3cdc8fa5e0:g:SoYAAOxyni9S~c4A
P
Post by: Parisien on 29 October, 2015, 07:20:51 PM
And a scatter gun search....on here?
http://www.ebay.it/sch/i.html?_odkw=lancia+fulvia&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xlancia+fulvia+INGRANAGGIO+DISTRIBUZIONE.TRS0&_nkw=lancia+fulvia+INGRANAGGIO+DISTRIBUZIONE&_sacat=0
P
Post by: Andrew1950 on 29 October, 2015, 08:24:07 PM
Thanks but I'd feel a lot easier obtaining the part from someone in the UK!
Post by: Parisien on 29 October, 2015, 08:31:04 PM
Indeed, but needs must sometimes, you have a pm with a few contacts, hope you're successful
P
Post by: Andrew1950 on 29 October, 2015, 09:03:46 PM
Hi Frank,
Kind of you to reply/Much appreciated. Will try tomorrow.
Post by: Parisien on 29 October, 2015, 11:21:36 PM
http://www.carandclassic.co.uk/car/C644524
This sounds a bit more promising.
P
Post by: fay66 on 30 October, 2015, 06:01:51 PM
Not a problem buying from Italy, usually if there's a problem it's the cost of carriage, you're also more likely to find one in Italy anyway.
8227 8)
Post by: Parisien on 30 October, 2015, 11:39:07 PM
http://www.ebay.co.uk/itm/LANCIA-FULVIA-V4-CYLINDER-BLOCK-TIMING-GEAR-X2-BEARING-X-1-/161868347439?hash=item25b01af82f:g:XJwAAOSwWnFV9BBl
These? No idea if series 1 if so....ends soon!
P
Post by: Andrew1950 on 31 October, 2015, 07:15:42 AM
Thanks Frank but the owner said it's an S2 or S3 which are slightly different.
Man thanks to the others who kindly replied.
Post by: Parisien on 02 November, 2015, 11:55:01 AM
Any luck since?
Another likely seller, but across the channel!
http://www.leboncoin.fr/equipement_auto/714050991.htm?ca=11_s
P
Post by: Richard Fridd on 02 November, 2015, 05:32:29 PM
I can have a look in my spare stock
Post by: Richard Fridd on 03 November, 2015, 05:45:11 PM
From my store. Is this s1 or s2?
Post by: Andrew1950 on 03 November, 2015, 06:49:23 PM
Thank you.
Unfortunately, I'm not a mechanic but maybe someone might know and reply.
