Title: Y10 Fire engine bay layout Post by: frankxhv773t on 30 September, 2015, 08:41:03 AM Having got my back suspension back together I went to start my Y10 only to get no response to the starter. I took disconnected various bits to get the starter motor out but having done a fox and reassembled everything my throttle cable is fouling on the alternator fan. I must have got something routed incorrectly but rather than fiddle about I wonder if anybody can help me out with the correct routing? I have been through my photos and don't have anything giving a clear picture because this area is generally hidden by the air filter housing. The workshop manual doesn't help either. Can anyone post a picture of the space between the carb and the right hand inner wing that shows the route of the various piped and cables?
Frank Title: Re: Y10 Fire engine bay layout Post by: fay66 on 30 September, 2015, 03:02:02 PM Frank,
I've looked at my GTi photos but being fuel injection there of no help, I'll try anf find the photos of my 1986 Y10 fire. Brian 8227 8) Title: Re: Y10 Fire engine bay layout Post by: frankxhv773t on 30 September, 2015, 09:31:49 PM Thanks Brian. The trouble is that in usual shots the area I want to see is masked by the air filter housing and the engine block. I am hoping someone with a Y10 Fire might whip off their air filter and take a shot down the back of the engine bay on the driver's side.
Frank Title: Re: Y10 Fire engine bay layout Post by: ben on 01 October, 2015, 09:19:27 AM I will get on to it today Frank!
Ben Title: Re: Y10 Fire engine bay layout Post by: ben on 01 October, 2015, 10:32:45 AM Hi Frank
On my Y10 the cable goes down from the bracket on the carb then loops in a u-bend back up from behind the alternator and then back through the bulkhead to the pedal. Hope the picture is good enough for you to see this. Ben Title: Re: Y10 Fire engine bay layout Post by: frankxhv773t on 01 October, 2015, 07:50:46 PM Thanks Ben, that should do it. On mine the throttle cable goes through a cable tie onto the trunking going forwards past the suspension turret. That would seem to be what is pulling it onto the alternator fan.
Frank |
