Model Technical and Interest => Flavia => Topic started by: bobhenry999 on 22 February, 2015, 01:37:51 PM
Title: 815 Coupe indicators
Post by: bobhenry999 on 22 February, 2015, 01:37:51 PM
Chaps,
I have just taken my car out for its first drive of the year, and for some reason the indicators are not working. They were fine a couple of weeks ago but now nothing. i have checked the fuse which is okay, although there is what looks like a flasher relay under the dash although I can`t see any mention of one in any of my wiring diagrams.
So, firstly, do I have a flasher relay, and if so how many wires should go on it, as the one I mentioned has 3 spades but only 2 wires connected to it.
Or any other suggestions of what might be up.
thanks,
Bob
Title: Re: 815 Coupe indicators
Post by: lancialulu on 22 February, 2015, 01:52:19 PM
Yupp you have flasher relay. Item 12 on the wiring diagram. Give it a flick.... but more likely you have a broken in the column switch
Post by: bobhenry999 on 22 February, 2015, 02:02:43 PM
Thanks Tim,
Looks like it should only have 2 wires after all, so thats not the problem. I`ll give it a whack and see if that spurs it into life.
Bob
Post by: neil-yaj396 on 25 February, 2015, 06:59:00 AM
Worth checking wherever the circuit earths as well?
Post by: lancialulu on 25 February, 2015, 10:15:47 AM
Column switch earth....
Post by: bobhenry999 on 25 February, 2015, 10:03:59 PM
Tim,
I did remove the column switch over the winter to remove the dashboard. Where is the switch`s earth as there are no wire on the switch itself ?
Post by: bobhenry999 on 06 March, 2015, 10:09:45 PM
Okay, tried a new relay but that made no difference. This is really getting on my nerves now, I hate electrics !
Post by: lancialulu on 06 March, 2015, 10:39:26 PM
Tim,
Bob
I seem to remember the unit earths itself so make sure the dome etc has a good metal to metal contact with the chassis and stalk.
Post by: bobhenry999 on 07 March, 2015, 05:10:49 PM
Tim,
Thanks, I will check that tomorrow.
Bob
