Title: Dedra service parts required Post by: Ed. on 02 November, 2011, 02:23:23 PM New member 1st post
Have a 92 Dedra and have to change the belts/waterpump before it goes back on the road. Problem being my local motor factors have it on their system, but cant get it in, and Fiat want almost €180 for the pump. Is there anywhere in the UK who can get genuine or generic ones in. Ive looked at the likes of Eurocarparts but they are out of stock. I am aware there are 2 types of pump as 1992 Dedras are in a 'crossover' year, so dont want to spend ages waiting on a pump to find its the wrong one! The last 4 digits of the chassis number are 2979, but can provide the full number if required TIA Title: Re: Dedra service parts required Post by: Angle Grinder on 02 November, 2011, 02:29:31 PM What engine size is your Dedra?
Title: Re: Dedra service parts required Post by: Ed. on 02 November, 2011, 02:36:59 PM Title: Re: Dedra service parts required Post by: HF_Dave on 02 November, 2011, 09:54:05 PM Welcome tro the fold Ed, Is your car a cat or non-cat. Some of the Themas were Cat fitted in 1992. :)
Title: Re: Dedra service parts required Post by: Ed. on 03 November, 2011, 11:06:11 AM Welcome to the fold Ed, Is your car a cat or non-cat. Some of the Themas were Cat fitted in 1992. :) Thanks Dave (its all your fault by the way) Will have to check when the weather is a bit drier Title: Re: Dedra service parts required Post by: HF_Dave on 04 November, 2011, 07:27:44 PM Cat or non-cat might help determine which type of water pump . :)
Title: Re: Dedra service parts required Post by: fay66 on 05 November, 2011, 01:02:45 AM Welcome to the fold Ed, Is your car a cat or non-cat. Some of the Themas were Cat fitted in 1992. :) Thanks Dave (its all your fault by the way) Will have to check when the weather is a bit drier Brian 8227 8) Title: Re: Dedra service parts required Post by: Ed. on 05 November, 2011, 02:55:47 PM Thanks guys - its non-cat
Title: Re: Dedra service parts required Post by: Ed. on 07 November, 2011, 10:19:55 AM Think Ill make it easier for myself and everyone by removing said pump at the weekend!
Title: Re: Dedra service parts required Post by: HF_Dave on 07 November, 2011, 10:44:31 PM Don't forget to mark up the belts before removal, bring the timing to TDC and tippex everything. :) Thanks, david.
Title: Re: Dedra service parts required Post by: Ed. on 12 November, 2011, 01:15:43 PM Is the balancing shaft timed on the 1.8 engine?
Title: Re: Dedra service parts required Post by: HF_Dave on 19 November, 2011, 08:33:07 PM Ed, the balance shaft has to be timed, there are timing marks on the pullys. if you dont time them properly the engine will be out of balance. thanks . David :)
Title: Re: Dedra service parts required Post by: Ed. on 23 November, 2011, 11:39:05 AM Does not look like it will be a DEADra for much longer :)
Title: Re: Dedra service parts required Post by: fay66 on 23 November, 2011, 04:28:23 PM Does not look like it will be a DEADra for much longer :) Hi Ed, Be nice to know another will make it back on to the road as they're certainly few and far between these days, if you need access to the manuals drop me an email. Brian 8227 8) Title: Re: Dedra service parts required Post by: HF_Dave on 26 November, 2011, 12:05:00 AM Do you mean Dead "ED" Ra, you could go on and on ;D
Title: Re: Dedra service parts required Post by: Ed. on 26 November, 2011, 08:57:08 PM Got some parts during the week...
Title: Re: Dedra service parts required Post by: LanciAlan on 27 November, 2011, 01:36:48 PM Looks like a timing belt kit and perhaps a water pump to me Ed? You probably ordered them a while ago and forgot about it. There may be something earlier in this thread that can shed light on it ....
Alan Title: Re: Dedra service parts required Post by: HF_Dave on 03 December, 2011, 08:55:45 PM Hi Ed, Does it say whatother engines the water pump fits. I see from the belt box that they fit the 16v as well. Thanks. David. :)
Title: Re: Dedra service parts required Post by: fay66 on 04 December, 2011, 12:12:20 PM Looks like a timing belt kit and perhaps a water pump to me Ed? You probably ordered them a while ago and forgot about it. There may be something earlier in this thread that can shed light on it .... The box on the left (5080) is the correct belt for RHD Dedra twin cams.Alan The box on the right (5620XS) which shows 16v refers to Dedra models that were only ever built in LHD and didn't come into effect until the 1994 facelift after RHD ceased. Apart from integrale all the Delta's listed are 2nd series Delta and they were LHD only as well. Having just looked at eper the OEM belts also carried different numbers for the 8v and 16v and on my 16v Themas the cam belt was considerably narrower than the Dedra 8v belts. Water pump part numbers also differ as on ePER. Brian 8227 8) Title: Re: Dedra service parts required Post by: Ed. on 01 April, 2012, 10:41:21 PM Now the evenings are longer, time to launch a fresh attack
Waterpump -on (https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/555024_10150649565249912_740359911_9496272_1332391186_n.jpg) Timing belt on, but not yet fully tensioned, a stud broke on the bottom pulley and my dads stud extractor was not co-operating! (https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-prn1/533796_10150649568149912_740359911_9496298_1809275442_n.jpg) Title: Re: Dedra service parts required Post by: Kevin MacBride on 14 April, 2012, 09:43:31 PM Would it not have been an idea to clean the scale from the pulleys before fitting, you could run the risk of damaging the belt.
