Title: timing belt Post by: m tulloch on 02 November, 2010, 12:35:24 PM Can anyone tell me if I will need any special tools, cam locking tool, etc, to change the timing belts on a 16v & VIS? Thanks. Title: Re: timing belt Post by: fay66 on 02 November, 2010, 04:35:57 PM Can anyone tell me if I will need any special tools, cam locking tool, etc, to change the timing belts on a 16v & VIS? Thanks. Hi Matthew, The only tool according to the manual is the belt tensioner tool that as far as I'm aware most people don't use anyway, if you're changing the belts you also need to change the tensioner bearings as well, these frequently seize if not changed and will throw the belts off with a lot of bent valves as a result. You also need to be very careful with the tensioning and make sure the that they're not too tight and don't whine, I had a belt shed it's teeth on my second 1993 Vis Auto at 18,000 miles, back about 1997. I finished up with 8 bent valves, and a head rebuild which cost over £1000, just pleased that Lancia picked up most of the tab, as they agreed the belt was faulty, there was also a modification that changed the toothed wheels along with a new belt fairly late on, to overcome broken belts, didn't help me though as mine had had them fitted from new! If you need the relevant pages from the manual please let me know. Brian 8227 8) Title: Re: timing belt Post by: m tulloch on 02 November, 2010, 08:45:22 PM Good enough, looks like I'll be busy this weekend! Hopefully the crank pulley nut will come off easily ::) Some chance ;D Title: Re: timing belt Post by: Kevin MacBride on 07 December, 2010, 12:01:55 PM In case you dont know...the crank pulley bolt is Left Hand Thread
Title: Re: timing belt Post by: m tulloch on 07 December, 2010, 04:59:53 PM I did know that but still can't get the thing undone! :'( Title: Re: timing belt Post by: Angle Grinder on 07 December, 2010, 07:05:53 PM Don't forget that you need to lock the Flywheel. There is a special tool for this, but someone nicked the Thema Consortiums.
Don't worry, you can get around this quite easily. On the front of the Gearbox bell housing these is a Flywheel sensor held in place by two small bolts (10mm I think). If you remove the sensor, you can then insert a short screwdriver with a broad flat head which will slot in between the teeth of the flywheel. Get an assitant to hold the screwdriver into a slot in the flywheel and then turn the engine by hand until the screwdriver takes up the slack and locks the flywheel. You should then be able to get the big bolt off with the assistance of a 4 foot long extension bar and some appropriate swear words! :o Remember to refit the sensor otherwise the car won't start! Easy to forget. ::) Title: Re: timing belt Post by: HF_Dave on 16 December, 2010, 10:04:28 PM I know I am coming to this a bit late but you know that the flywheel bolt is a left hand thread :)
