Model Technical and Interest => Beta and Montecarlo => Topic started by: neil-yaj396 on 08 April, 2010, 03:26:25 PM
Title: Cambelt tensioner spring
Post by: neil-yaj396 on 08 April, 2010, 03:26:25 PM
Has anyone got any tips as to how to get the cambelt tensioner spring back on? The method shown in Haynes using a screwdriver as a lever is fine with the engine out, but 'in car' the screwdriver fouls the front cam wheel so that the spring end is shy of it's hole.
How annoying as I didn't need to take off the belt afterall! :'(
Any idea most welcome so the car can get off for it's MOT under it's own steam.
Neil
Title: Re: Cambelt tensioner spring
Post by: St Volumex on 09 April, 2010, 07:00:04 AM
Hi Neil,
On a Beta I've done it by re-fitting the pulley and spring together over the stud at the centre of the whole, but I'm not sure if there's enough space on a Monte to do the same.
Sorry if this sounds intelligible, but words fail me at the moment.. ::)
Post by: neil-yaj396 on 09 April, 2010, 04:28:09 PM
Thanks, presume you mean take off the pulley all together then re-fit with the spring? I'm doing it on a Beta so space shouldn't be a problem.
Neil
Post by: St Volumex on 10 April, 2010, 07:54:29 AM
Yep, that's it.  :)
Post by: SanRemo78 on 12 April, 2010, 06:56:48 PM
I used to use a long thin open ended spanner, just the right amount of leverage to let the spring drop back into the hole on the tensioner. But much easier with the engine out..
Post by: pewe on 12 May, 2010, 11:01:06 AM
For future ref. when adjusting my tensioner I use a length of push-bike inner cable (Bowden brake cable).
This is inserted through the hole in the plate, doubled back across the water-pump (i.e right side of engine) and tensioned by hooking it, then tying it around a G clamp or valve-spring compressor (screw type).
Find a suitable place on the body or engine for the clamp pivot and wind the cable into tension.
Can't see why that shouldn't work on the spring itself.
Saves skinned knuckles and is a lot more accurate than trying to lever it with a screwdriver.
HTH.
Cheers, Pewe.
