Model Technical and Interest => Flavia => Topic started by: msh2908 on 07 November, 2021, 11:20:16 AM
Title: Flavia Copue 2000 (1970) - front top ball joint
Post by: msh2908 on 07 November, 2021, 11:20:16 AM
Hi everyone,
i have a split rubber on a top ball joint - is there any guidance on how to replace the ball joint?
With thanks
Title: Re: Flavia Copue 2000 (1970) - front top ball joint
Post by: lancialulu on 07 November, 2021, 11:26:56 AM
Have you checked if the ball joint is still functioning or is loose. The only way to check quickly is to restrain the spring. If the ball is OK I would just replace the rubber boot available from Omicron.
Other wise it is a suspension dismantle as the joint is pressed in the top arm and not possible IMHO todoin situ. The club has a tool to withdraw the joint but you need a press for a new one.
Post by: Richard Fridd on 07 November, 2021, 12:54:08 PM
Not sure if this is a top or bottom ball joint, but I have come across it when looking for those cv joints. It is unused and now surplus from my previous Fulvia project. It is the type which has a  threaded hole for a grease nipple. Richard
Post by: msh2908 on 08 November, 2021, 01:19:41 PM
What is the easiest way to restrain the spring?
Post by: lancialulu on 08 November, 2021, 05:21:28 PM
Omicron sell or at least used to sell a tool that restrains the front spring.
Post by: Richard Fridd on 08 November, 2021, 06:46:26 PM
How about two pieces of metal drilled to use threaded rods and nuts as a spring clamp, which maybe would need an adapter to fit whatever crossmember there is. Or does this only work with Fulvias? Richard
Post by: msh2908 on 12 November, 2021, 02:31:28 PM
The guys in Norfolk don't hire this tool - so does anyone have an image of a tool they have made to clamp the spring?
Post by: lancialulu on 12 November, 2021, 03:54:01 PM
Do they still sell them?
It is 3 parts and a nut and bolt.
Post by: Angle Grinder on 18 November, 2021, 03:00:59 PM
pic of tool for locking spring in place.
Post by: Angle Grinder on 18 November, 2021, 03:01:58 PM
and another angle
Post by: Angle Grinder on 18 November, 2021, 03:02:46 PM
and again
Post by: Angle Grinder on 18 November, 2021, 03:04:24 PM
and this is the metal bar that you need to bolt onto the spring housing so that you have enough metal extending to hand the red tool onto to keep the spring held up.
Post by: Angle Grinder on 18 November, 2021, 03:05:37 PM
And this is how it looks when in operation...
Title: Re: Flavia Coupe 2000 (1970) - front top ball joint
Post by: Brian Long on 19 November, 2021, 05:51:22 AM
Unfortunately, on the 2000 Coupe the spring housing does not protrude sufficiently to allow anything to rest or be bolted onto it. So I think that tool wont be able to be used.
Post by: lancialulu on 19 November, 2021, 07:22:10 AM
Brian that is the correct tool. I have similar. You are correct that the Flavia and S1 Fulvia do not have any spring housing to speak of which is what the “20x40”mm bar persorms.
Post by: msh2908 on 19 November, 2021, 02:20:03 PM
Thank you everyone for your.  The images of the spring tool is very useful. The Flavia have kindly lent me their's.  i just need to get the right size hub nut tool. Again the consortium have sent me to two, but both are too large.  The diameter of the hub recess that houses the 6 pin nut is 61mm.  Does the LMC have one for members to use?
