Model Technical and Interest => Fulvia => Topic started by: andyps on 27 June, 2021, 08:34:54 PM
Title: Cylinder head skimming - valves out?
Post by: andyps on 27 June, 2021, 08:34:54 PM
A quick question I'm hoping someone can help with, I've taken the cylinder head off my 1.3 S2 with the intention of taking it to get it skimmed tomorrow but looking at it the inlet valves are very close to the surface of the head, so much so that they could potentially get a small amount ground off them if the head is skimmed - do they need to come out for the skimming? The car doesn't have its original engine so I'm not absolutely sure of the origins of the components. Any help appreciated, I didn't really want to take the valves out at this stage but can do if necessary.
Title: Re: Cylinder head skimming - valves out?
Post by: Jai Sharma on 27 June, 2021, 09:51:48 PM
I am no expert but I have never heard of a Fulvia head being skimmed with the valves in.
Post by: andyps on 27 June, 2021, 10:38:07 PM
Thanks Jai, I think it probably needs the valves out looking at it but was hoping to get it skimmed and then do the valves one by one so I can be sure they go back in the same place!
Post by: lancialulu on 28 June, 2021, 08:10:15 AM
Get 8 pots labelled E1 to 4 and I 1 to 4 and you cannot go wrong. You will still need to relap the valves in, and or have seats recut if changing the valves/guides on inspection.
Post by: andyps on 28 June, 2021, 10:28:44 AM
Looks like I need to eat a lot of yogurt today ;D
Thanks Tim, I'll get them out tonight if I can find my valve spring compressor, haven't used it for a long time. Reason for my original question is that other heads I've had skimmed were fine with the valves left in place but when I looked closely I figured that can't be done with the FUlvia one.
Post by: davidwheeler on 29 June, 2021, 08:34:56 PM
I have a set of number punches to use on valves but I guess it is different with a Lambda!
Post by: lancialulu on 30 June, 2021, 04:59:13 AM
you may have to buy another valve spring compressor due to the width of the head. The large Clarke one from Machine Mart has a deep enough “U”.
Post by: andyps on 05 July, 2021, 10:43:45 PM
I did buy a larger valve spring compressor - got one from Amazon for convenience but it is going back because the quality is shocking, just about managed to get it to work but the part which sits against the valve face kept falling off. Head is now skimmed and back on the car, all reassembled but a bit late this evening to fire it up without upsetting the neighbours!
