Model Technical and Interest => Aprilia, Ardennes and Ardea => Topic started by: Tony Stephens on 29 November, 2020, 07:51:47 AM
Title: Fuel level indicator wiring
Post by: Tony Stephens on 29 November, 2020, 07:51:47 AM
Has anyone sourced a suitable harness and brass terminal tags to replace the original Aprilia fuel level indicator wiring harness?
My gauge and tank unit seem OK (well, repairable), but the wiring is tragic and certainly needs replacing. I can make one up easily enough, but a pointer to a suitable multicore cable would be helpful.
Title: Re: Fuel level indicator wiring
Post by: simonandjuliet on 29 November, 2020, 12:02:12 PM
Hi Tony, I used a multi core wire from a computer supplier and then bound it myself with loom tape. I am re-using the brass eyes having un-soldered them from the old unit
Post by: Spanner Man on 29 November, 2020, 04:48:06 PM
I buy most things direct from China
https://a.aliexpress.com/_BSj7qF
Post by: peterblenk on 08 February, 2021, 12:03:16 PM
Tony, Winston Teague and David Aston rewired my car, and they sourced a new multi-core cable for the petrol tank sender from somewhere. It would be worth asking them, if you have not found a source yet. You should be able to reach them at vehiclewiring@googlemail.com or 07971415277. Peter
