Model Technical and Interest => Fulvia => Topic started by: my69S1 on 21 September, 2020, 12:47:52 PM
Title: Coolant Hoses
Post by: my69S1 on 21 September, 2020, 12:47:52 PM
Did the coolant hoses change length from the S1 to the S2?
I ordered new top and bottom rad hoses for my S1 and both of them are longer than the ones on the car currently.  The bottom one is especially longer, by about 10cm.  Am I suppose to cut them to fit?  I haven't heard back from the supplier but they sell the same hoses for all models of the Fulvia.  I can post pictures if that helps.
Title: Re: Coolant Hoses
Post by: lancialulu on 21 September, 2020, 04:18:31 PM
You have to generally trim them. Just a little..... or they will be too short. Are they silicon? If so use a very sharp blade and dont go off line
Post by: my69S1 on 22 September, 2020, 12:42:02 PM
Here is a picture of the lower hose.  It has the correct bend but is considerably longer than mine.  Or maybe something is wonky on my car?
Post by: Jaydub on 22 September, 2020, 04:27:21 PM
If the bend is correct, just carefully cut off the excess as Tim suggested.
Post by: rogerelias on 22 September, 2020, 07:06:18 PM
New one does not look right to me ,when placed alongside the one fitted to the car, it looks like the new hose does not run straight as it should do, it looks like it's veering off, so when cut and fitted may end up with a kink in it.
