Model Technical and Interest => Fulvia => Topic started by: jus on 20 July, 2020, 08:09:14 PM
Title: DCOE choke size
Post by: jus on 20 July, 2020, 08:09:14 PM
Just cleaning the DCOE 45s on the Fulvia (only had it a week or so), and noticed that one of the chokes is 32mm, and the other three are 34mm. I'm assuming that it's a mistake - and that they should all be equal? Is there any reason why this might be intentional?
Thanks for any info.
Title: Re: DCOE choke size
Post by: lancialulu on 20 July, 2020, 09:13:02 PM
36 works great on correctly jetted 45 DHLA’s I have on my Fulvia 1600... The std solex 42 had 34 chokes.
Post by: Charles Frodsham on 21 July, 2020, 11:56:53 AM
I’m no expert, but it doesn’t sound right to me. When I bought my car, it had an odd size trumpet, which was duly rectified, so it can happen!
Post by: jus on 22 July, 2020, 08:10:51 AM
I've got some 36mm chokes coming and 2 refurb kits. Can anyone recommend a good cleaning product for the inside and outside of the carb bodies? A brass wire brush seemed to clean up the outside pretty well, and a blast of carb cleaner moves some grime, but they could look better. I don't really want to have them vapor blasted - they go a bit pale and look porous.
Post by: Jay on 22 July, 2020, 12:15:18 PM
I used a friends ultrasonic bath and cleaner some years ago which worked really well, although it was quite a large one
Post by: Neil on 22 July, 2020, 04:54:53 PM
Use an ultrasonic cleaner with some correct carb cleaning solution added to the water, you will be amazed what comes out of them and they look a whole lot better too.
Post by: angelorange on 06 September, 2020, 09:50:03 AM
Fulvia likes bigger than "normal" chokes cf inline engined cars. However, unique cranked over v4 layout means unequal length inlet tracts which have room for experimentation. This might be such as with inlet trumpet sizing v torque required.
Really need a rolling road to get best out of these carbs.
