Model Technical and Interest => Fulvia => Topic started by: cannylancia on 20 August, 2018, 07:32:33 PM
Title: Fulvia fuel cover
Post by: cannylancia on 20 August, 2018, 07:32:33 PM
Has anyone changed out the fuel filler cover on a Fulvia HF. I had to cut mine due to a broken lock and was wondering if it is possible to take the 5mm vertical pin out and replace the cover. Looks almost impossible to me ???
Title: Re: Fulvia fuel cover
Post by: Neil on 20 August, 2018, 07:58:50 PM
It can be done, there is vertical pin and from memory a spring there too, many  fits between the two horizontal 'runners' there are one or two rubber grommets you can get from inside the boot to remove the pin, a good torch or headlight is required.
Post by: cannylancia on 21 August, 2018, 12:25:26 PM
Many thanks - will have a look and try.
