Model Technical and Interest => Flavia => Topic started by: colinw on 01 May, 2018, 01:12:27 PM
Title: Steering box - oil
Post by: colinw on 01 May, 2018, 01:12:27 PM
I would like to change the gearbox oil on the steering box on my 1800 Flavia Coupe but as yet the drain plug? has not revealed itself.  Sorry to ask such a basic question but can anyone help? Thank you
Title: Re: Steering box - oil
Post by: Angle Grinder on 01 May, 2018, 02:45:44 PM
You'll need a big syringe and a bit of tubing to suck it out, but I suspect most unrestored Flavia steering boxes have seals that let the oil seep out. I use a Penrite product that has a viscosity somewhere between oil and grease. If you warm it up it will pour into the steering box and then it "sets" with a viscosity that prevents it leaking out past old seals.
Post by: colinw on 02 May, 2018, 05:59:36 AM
Thank you for the reply. As I suspected and you confirmed one would have to remove a flange and seal to drain the box. Interesting idea about using a thicker oil. Can you let me know the viscosity?
Syringe idea is interesting I shall give it  try. Have cleaned up the box and now I look for the potential leaks.
Thank you again
Post by: lancialulu on 02 May, 2018, 07:02:51 AM
Thank you again
I use EP140
Post by: Angle Grinder on 02 May, 2018, 01:41:38 PM
I think it was this product, but I'd need to have a look in the garage to check what bottle I've got.  https://www.penriteoil.com.au/products/steering-box-lube (https://www.penriteoil.com.au/products/steering-box-lube)
Post by: JohnMillham on 02 May, 2018, 05:40:10 PM
That's what I have used for years in the Lambda and Augusta. They used to leak, but don't any more.
Post by: colinw on 02 May, 2018, 07:56:08 PM
Many thanks to all of you and the recommendations, I shall follow it through and hopefully another part of my Coupe shall become leak free.
