Model Technical and Interest => Appia => Topic started by: simonandjuliet on 19 August, 2022, 06:00:43 AM
Title: Oil filter - early 1st ser
Post by: simonandjuliet on 19 August, 2022, 06:00:43 AM
Another question for you all .....
The 1st series Appia that we are working on doesn't have an oil filter fitted, it is blanked off where the mount is normally found - it looks original and properly done - not just a piece of metal bolted on !
Can anyone confirm that this was "normal" and second can you retro-fit an oil filter set up ? I have the bits ......
Title: Re: Oil filter - early 1st ser
Post by: mikeC on 19 August, 2022, 06:11:13 AM
My early car does not have an external filter, nor any facility for fitting one; just an internal gauze filter in the sump.
Post by: simonandjuliet on 19 August, 2022, 06:23:41 AM
Thanks Mike, I'll try and take a photo for comparison - do you not have a blanking plate ?
Post by: lancianut666 on 20 August, 2022, 06:46:39 AM
The oil filter mounting is a direct fit when you take the blanking plate off...not sure about the stud length as the oil filter housing is fairly thick...the Consortium has the parts to convert your S1 engine. You might need a different oil feed pipe for the pressure gauge.
Clarkey
Post by: mikeC on 20 August, 2022, 12:15:36 PM
As far as I can see I've no blanking plate - whereabouts should I be looking?
Post by: simonandjuliet on 20 August, 2022, 06:01:48 PM
Here are some lubrication charts for S1 & S2 Appias - they seem quite different - but to answer your question , the filter is by the petrol pump
Unfortunately the only S1 engine that I have spare already has a filter, so I can't verify the differences easily.
This is when we realise what, and whom, we have lost ---- Don with his enormous depth of knowledge would have known in an instant !!
Post by: mikeC on 20 August, 2022, 07:30:41 PM
That's sort of where I was looking - no blanking plate at all:
(https://i.postimg.cc/9F0szRx0/P1070647.jpg) (https://postimages.org/)
(https://i.postimg.cc/bN5WnyMT/P1070648.jpg) (https://postimages.org/)
Title: Re: Oil filter - early 1st mounting studs
Post by: lancianut666 on 20 August, 2022, 09:38:43 PM
the oil filter mounting is below the fuel pump mounting studs
Post by: a1city on 21 August, 2022, 10:11:49 AM
Hi, when we rebuilt my series 1 we removed the blanking plate
And fitted the later canister type , you may need the pipe but I can,t remember.
No problem with the oil pressure gauge. Dave
Post by: mikeC on 21 August, 2022, 02:16:27 PM
Not on mine!
(https://i.postimg.cc/YSGByXG1/P1070677.jpg) (https://postimages.org/)
Post by: lancianut666 on 21 August, 2022, 09:35:44 PM
I stand corrected...perhaps I could interest you in a later crankcase?
Clarkey
Post by: mikeC on 22 August, 2022, 03:00:16 PM
Thanks, Jim, but having spent a fortune rebuilding this engine, I'm not looking for more work!
Post by: simonandjuliet on 22 August, 2022, 04:50:45 PM
Here we go - Lancia through the ages .... I wonder at what point they changed the crankcase ? My 1st ser engine from a commercial has the filter
Post by: lancianut666 on 22 August, 2022, 06:34:05 PM
Perhaps all the worn out early S1 cars persuaded them to fix the problem...strange they were still selling them with the blanking plate and the crankcase cast to take the filter but no filter.
Clarkey
Post by: mikeC on 23 August, 2022, 06:09:20 AM
Did they add the filter when they changed to thin-wall shell-bearings?
Post by: GG on 23 August, 2022, 01:43:00 PM
Good idea. A look through s.1 parts book (1953) shows no mention of a filter.
Post by: nistri on 23 August, 2022, 02:32:54 PM
I believe the filter was routinely fitted after the first 10,000 S1 engines. I have seen S1 engines with factory fitted filters, Andrea
Post by: Sebastien on 25 August, 2022, 10:38:35 AM
Went back to the Lancia bible, 2nd edition, Wim Oude Weerninck (page 171):
....During a three-lifespan the 1st series was changed in many respects. After a few thousand engines had been produced the gauze oil filter was replaced by a full-flow filter..... Approximately 20,000 of the Appia 1st series were made before the introduction of a 2nd series.
So the 1st series parts book (1953) mentionned by GG must be a very early one. A later one should mention the car number at which the change took place.
Post by: lancianut666 on 27 August, 2022, 10:23:57 AM
All of the engines I have seen have the gauze filter in the sump as well as a cartridge filter in the orange canister.
Clarkey
