18 April, 2024, 07:27:16 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
, for Database Administrator e-mail
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Gamma
Gamma Camshaft
Pages: [
1
Go Down
« previous
next »
Author
Topic: Gamma Camshaft (Read 4647 times)
Brian Long
Gamma Camshaft
on:
07 August, 2017, 08:02:11 AM »
I have been watching a friend of mine rebuild a Gamma engine. One camshaft seemed to have unusual inlet and exhaust lobe positions, i.e.on the RH camshaft they looked 'normal' i.e. the inlet and exhaust lobes had the usual looking timing positions for both cylinders.
However, the LH camshaft front cylinder lobes, I think they were, inlet and exhaust lobes were positioned diametrically opposite each other. The other cylinder's lobes on that camshaft looked 'normal'.
Can anyone shed any light on this apparent anomaly?
Brian Long
Charles
Re: Gamma Camshaft
Reply #1 on:
05 September, 2017, 01:09:02 PM »
A very interesting observation Brian. The picture shows that the inlet and exhaust lobes for both cylinders on the nearside (no1 & no3) are both almost diametrically opposed whereas those on the offside are close together. The reason is that the Gamma is a boxer engine and so the plane of one bank of cylinders is 180 degrees away from the other in terms of rotation so the lobes of one cam are also rotated 180 degrees in relation to the other. One thing that I had not noticed before, despite being a Gamma owner for 20 years is that the position of the inlet and exhaust lobes are swapped on the cams. Those who look closely will see that the lobes are not symetrical, they have a sharply lifting side and a more gently lifting side. On the n/side camshaft the inlet lobes are in the middle with the exhausts at each end. You can see that the inlet cam lobes snap the valves open very quickly and then close them more gently whereas the exhaust lobes do the opposite. Close examination will reveal that the lobes on the o/side cam are the other way around i.e. inlets at each end with the exhausts in the middle.
Augusta berlina, Appia S3 berlina
Flaminia convertible 2.8 3c Touring
Beta spider S1 1600, Gamma berlina S1
Gamma coupe S1, Delta 1.6 multijet
Re: Gamma Camshaft
Reply #2 on:
05 September, 2017, 06:38:47 PM »
An interesting explanation but it doesn't seem to explain why the lobes on one cam act on the valves in quick succession whereas on the other cam they operate half a turn apart. The answer seems to be that the rocker arrangement on one bank of cylinders is completely different to the other bank.
ben
Re: Gamma Camshaft
Reply #3 on:
05 September, 2017, 08:49:13 PM »
The reason for the difference in the relative positions of the lobes on the l/h and r/h camshafts of the Gamma engine is as Charles says due to the 180 degree rotation of the plane of the alternate cylinders. However such a rotation on its own would not require any change to the relative positions of the lobes were it not for the fact that at the same time the relative positions of the inlet and exhaust valves are reversed so that the inlet port stays on the top of the engine and the exhaust port at the bottom.
For any particular cylinder, observation of the relative positions of the in and ex lobes on the camshaft does not give a direct indication of the relative timing of the valve openings unless the valves are in line(as is the case for many common engines of course).
For the Gamma with its hemispherical combustion chambers and inclined valves the valve actuation is via rockers which are pivoted on opposite sides of the camshaft.The relative positions of the cam lobes has to take account of this.
For such a design if we imagine the cylinder to be upright the relative cam lobe positions would be like the Gamma L/H camshaft if the exhaust was on the L/H side of the engine and the inlets on the right.However if the exhaust was on the R/H side of such an engine ie if the crossflow goes the other way across, then the relative cam lobe positions would be like the R/H Gamma camshaft.
With reference to Brians original observation if he thinks the R/H camshaft lobes look "normal" that suggests he is familiar with crossflow engines with the inlets on the R/H side and the exhausts on the left!
Re: Gamma Camshaft
Reply #4 on:
05 September, 2017, 09:17:43 PM »
Thanks Ben. That makes sense to me now. You live and learn.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
