25 April, 2024, 11:29:10 PM *
Pages: 1 [2]   Go Down
Author Topic: Flamina Touring Brake Lock Issue  (Read 12201 times)
« Reply #15 on: 03 September, 2016, 12:01:18 AM »
Nice to see another contributor,
My car developed this problem, about 200miles after purchasing I got the impression that this was a known fault on the car but a quick Servo strip down gave it a bit more life. But the brakes started to bind quite a lot and I started to fall out of love with the car, so a quick phone call to Norfolk suggested that next time they seized just loosen the pipes on the servo to each of the circuits to free the brakes and ascertain which ones were binding.  It turn out the backs were sticking more than the fronts, and as the all the pistons had been previously lined 15 years prior, I sent the servo to them for a complete rebuild. Since then the brakes have been really strong and absolutely 100%, although you do need to drive these car regularly.
I believe that the back brakes binding were part of the cause for my stub axle to sheer a couple of years ago, another thread on this forum. As when I check the clutch it wasn’t in great condition with so much burning and cracking, where I think someone (before me) had just tried to fight the brakes. Luckily I had an old spare, and if the brakes were jammed all this torque would have been taken up through these shafts.
Here you go
file:///C:/Users/Owner/Downloads/FFF_Dunlop_Duplex_S2_Eng.pdf.
Charles
« Reply #16 on: 03 September, 2016, 02:05:49 PM »
I keep my Flaminia brake servo (as freshly serviced by Omicron) on a shelf in my garage!  For the last three years I have been driving around with one of these - http://www.s-v-c.co.uk/product/dual-remote-servo/ - which was easy to fit and works a treat with no hint of problems.  I had to make a couple of simple brackets which mount to the original mounting cotton reels plus one small bracket fixed to the inner wing.  Also a hydraulic switch for the brake lights was required. The whole thing is easily reversible (i.e. put back to original) with about an hour's work but I like the reassurance of knowing that when I hit the pedal, the car will stop.
Charles Frodsham
« Reply #17 on: 03 September, 2016, 05:53:34 PM »
Lots of good information guys.
The servo obviously causes a lot of issues as can be seen from the replies.
If you want to keep the car standard, with standard/original pipe work, and have superb brakes, year in and year out, without having to do periodic rebuilds, to my mind the ClassicLancia item cannot be beaten, as it fundamentally removes the corrosion issue and also the internal component wear that components of this age will undoubtedly have. This isn't an advert, just the result of a lot of time and money! I wish I had just done it sooner.
pchflyer
« Reply #18 on: 04 September, 2016, 04:56:14 AM »
Can someone explain again the functional differences between the ClassicLancia-type servo and the original unit? I do see the original has a separate fitting for the brake light sensor, and what else? Thanks for the great info.
Brian Long
« Reply #19 on: 04 September, 2016, 11:42:29 AM »
Have you checked your hoses to make sure they haven't swelled internally. The booster can force fluid into the calipers but the pressure can't relieve because it is trapped in the caliper(s).
Charles Frodsham
« Reply #20 on: 04 September, 2016, 07:58:53 PM »
Good point Brian about the flexible pipes.
The 'Classic Lancia' servo is basically an original servo with re-engineered internals.....stainless steel material for pin and both piston housings. Although sold as 'new' you have to provide a donor servo so that production can continue. So all fittings, sensors, operation exactly as the original. As far as I can see the only problem is the price...but you should only ever have to buy one.
AandSRuggeri
« Reply #21 on: 05 September, 2016, 11:23:48 PM »
Hi there, In my opinion, the Flaminia as delivered from the factory has pluperfect brakes, way better than anything of the period that I've driven and dare I say it, much better than a lot of considerably more modern cars as well. True, a wobbly servo will provide no end of entertainment - I remember that my GT had a particular wheeze for pulling violently to the left on the first couple of applications and would aferwards brake in a dead straight line from 110+ mph without a murmer. Once these systems are up and running as per factory spec they are gold standard and have no need for modification - a sentiment that funnily enough I find true for the rest of the car as well...
Regards,
Stef
1954 4th Series Aurelia B20
1965 Flaminia GT 3C 2,8
pchflyer
« Reply #22 on: 16 September, 2016, 04:38:37 PM »
While attempting to troubleshoot problem #1, stuck brakes, the car developed problem #2, a strange short at the battery, which could have been disasterous, but luckily just killed the battery and nothing else. For expediency's sake, I'm leaning toward ordering a backup servo as recommended by Charles while the original servo is sent away, if needed. I see in your pic the air valve is missing, and some lines don't appear to be connected. Is this because the photo was taken mid-installation, or did you modify it in some way?
pchflyer
« Reply #23 on: 16 September, 2016, 04:51:08 PM »
I found this excellent description of remote servo operation, complete with drawings and possible clues to servo failures: http://www.mgb-stuff.org.uk/servo.htm
Pages: 1 [2]   Go Up
