Pietro
« on: 04 December, 2015, 10:18:04 AM » |
Hi All,
I am a newby to the club so please forgive me if I have posted this in the wrong place or transgressed some other rule or protocol. Please feel free to put me right.
A very brief introduction. I have two Fulvia's a 1.3S which I race and a Zagato which I am planning to restore, it is presently pretty much down to a shell.
My latest problem, I can find no way of removing the wiper mechanism from the body on the passenger side (its a RHD car). Has anyone experienced similar problems and found a solution. Am I being stupid ?
Any help and instruction on how to use the forum properly gratefully recieved
Many thanks in advance
Pete (my name is Pietro but people call ne Pete for ease)
« Reply #1 on: 04 December, 2015, 12:00:40 PM » |
Hi Pete, Any thing like this goes under the model so you just scroll down until you find the right place. No problems, it's not an uncommon problem so I'm sure it's been on here before but I can't put my finger where, however someone else will answer with the right place pretty quickly. You can also try at lancist.net an American run site but where many of us also post, try this link, http://www.lancisti.net/forum/showthread.php?7395-Replacing-wiper-mechanism&highlight=wiperRegards Brian 8227
roddy
« Reply #2 on: 04 December, 2015, 11:58:02 PM » |
Hello Pete
You will have to remove the cold-air pick-up box which feeds the heater fan to the interior. Remove the wiper arms from the taper splined spindles (I find it handy to put two pieces of masking tape on the screen where the blades are, which ensure the arms go back on the same spline). The wiper motor attaches to the bulkhead in two places with rubber metalastic isolation bushes. The nuts can be found in the footwell in front of the glove compartment. The motor attached to the frame (which crosses over to the drivers side) can now be removed by dropping the spindles down through their housings, lifting the threaded ends of the bushes out of their holes, and pivoting the complete assembly forward.
Regards - Roddy
Roddy Young Dunfermline, Fife
1970 Fulvia Sport S1 1.3S
« Reply #3 on: 05 December, 2015, 10:03:36 AM » |
Ah, that's how it's done! I spent hours a few months ago fiddling and struggling to get mine back in!
Pietro
« Reply #4 on: 08 December, 2015, 01:16:29 PM » |
Thanks Guys, much appreciated.
I will have a go at it tomorrow night when I get home, and a further thanks to Brian for the link. I think I am following in the persons footsteps and the pictures will be invaluable if I ever get to trying to put it all back together again. The car is now down to a shell, barring a couple of items which are refusing to be removed.
I suspect I will be pestering you again soon as I start to strip and refurb / replace the many components.
Thanks Again
Pietro
Richard Fridd
« Reply #5 on: 08 December, 2015, 07:09:37 PM » |
Which items are refusing removal?
Pietro
« Reply #6 on: 09 December, 2015, 01:28:12 PM » |
Nothing notable that will not come off with a little further persuasion, things like the accelerator pedal and a few bolts which it's looking like will need to be cut off and drilled.
Removing everything else, from the body, has been relatively easy, just a few resulting cuts and bruises. The shell is remarkably good shape but some metalwork will be required once it has been dipped and primed.
Do you have one ?
Cheers Pete
Richard Fridd
« Reply #7 on: 09 December, 2015, 04:23:57 PM » |
Had coupe, sedan(repairs detailed in the 'Fulvia' board) and two sports, one of which is in the JLG65K thread, also somewhere within the Fulvia board.
Pietro
« Reply #8 on: 14 December, 2015, 04:23:59 PM » |
Hi,
Still no joy and few more hours lost. Thinking of cutting it out and worrying baout it when I come to rebuild. Are they in short supply or readily available. Any idea ?
Many thanks
Pietro
