01 July, 2022, 11:17:43 AM *
Author Topic: Gearbox dip stick  (Read 5363 times)
Justin McArdle
Fulvia Berlina 2C
« on: 01 December, 2015, 08:45:01 PM »
I have an oil leak on the top of my gearbox which necessitates occasional topping up. I find it very difficult to see the level on the black plastic dipstick. There are two small marks on the dipstick but difficult to see the level and I am wary of overfilling. Any tips or suggestions?
Lancia 2000 HF Coupe
Fulvia Berlina 2C
« Reply #1 on: 01 December, 2015, 10:32:18 PM »
The full mark is about 1/4 inch from the lower mark. Very difficult to see. Use a clean rag to dry off the dip stickesp in the groove to see the level better.
« Reply #2 on: 01 December, 2015, 10:51:06 PM »
If the marks are difficult to see could you cut a bit of a notch in the side of the dip stick level with each mark to make it more distinguishable?
Frank T
« Reply #3 on: 02 December, 2015, 05:16:32 PM »
A thin line in a good enamel paint or drill a hole through the mark.
Justin McArdle
Fulvia Berlina 2C
« Reply #4 on: 02 December, 2015, 08:42:41 PM »
Thanks for the input from everyone. The main problem is that unlike the metal sump dipstick where the level can be seen very clearly the gearbox dipstick is black, plastic and cylindrical. It's just difficult to see the oil on the dipstick - and the microscopic level indicator dots don't help either!
 I usually lie the dipstick against some kitchen roll to see where the oil level is.
Fulvia Berlina 2C
« Reply #5 on: 02 December, 2015, 10:23:27 PM »
When checking any oil I always have a piece of white kitchen paper to wipe the dip stick before reinserting it to take a reading so I would be with you on laying it on white paper towel to get the level. However if you drilled through where the microscopic dot markers are as Brian suggests you could just hold it up to the light. If you can see light through it then the oil isn't up to that level.
I expect a spare dipstick to experiment on would be nice.
Frank T
John B
« Reply #6 on: 03 December, 2015, 03:04:17 PM »
Wind some white masking tape around the dip stick after wiping the oil off and then re-insert.
Should make it a lot easier to see the level against a lighter background.
Remove the tape afterwards though.
1961 Appia S3
1969 Fiat 850 Special
Justin McArdle
Fulvia Berlina 2C
« Reply #7 on: 04 December, 2015, 02:14:12 PM »
For the uninitiated a couple of photos of the dips tick in question.
Fulvia Berlina 2C
John B
« Reply #8 on: 04 December, 2015, 03:25:34 PM »
Seems like Lancia lost the plot when they designed that!
1961 Appia S3
Neil
« Reply #9 on: 04 December, 2015, 05:35:16 PM »
How about a thin band of heat shrink insulation in a suitable light colour between the upper and lower marks, then shrunk on permanently with gentle heat?
Neil
386
1973 Fulvia S2 1.3
« Reply #10 on: 05 December, 2015, 11:13:20 AM »
And I thought it would be like the Fulvia one, how wrong can you be, what an unispring design. Shocked
« Reply #11 on: 05 December, 2015, 11:28:08 AM »
not s1 but same as S2/3 as esentially same 5 speed box...
« Reply #12 on: 05 December, 2015, 05:40:08 PM »
I still think you could put some holes in it to better see the level.
Frank T
Page created in 0.07 seconds with 21 queries.
