29 March, 2024, 03:37:41 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Ypsilon, Musa and Y10
Y10 front suspension assembly
Pages: [
1
Go Down
« previous
next »
Author
Topic: Y10 front suspension assembly (Read 4505 times)
on:
05 October, 2015, 02:12:40 PM »
Having dismantled my front suspension to replace some boots and bushes I now can't get it back together again. Neither the workshop manual or Haynes manual is specific about the order of reassembly but no matter how I approach it the last bit is nowhere near meeting up with the bolt holes.
Can anybody advise me on the order of reassembly and what the trick is to get everything aligned?
ben
Re: Y10 front suspension assembly
Reply #1 on:
05 October, 2015, 08:51:36 PM »
Which specifically are the bolts that won't line up Frank?
Ben
Reply #2 on:
05 October, 2015, 09:30:50 PM »
Ben
I have attached the strut top mounts, reaction bar at both ends and the bottom ball joint to the track control arm. The inner end of the track control bar can be persuaded into the chassis mounting but the hole in the bush is not in the same plane as the bolt holes in the chassis. I can't get a grip on the track control arm to force the holes into alignment. Jacking up under the lower ball joint forces the bottom of the strut out to the side of the body so the inner end of the track control arm can't be inserted into the chassis mounting bracket. Brian Hilton suggested removing the anti-roll bar but that hasn't allowed any flexibility in the track control arm to line up the bolt holes.
I could keep working through all the permutations of fitting things in different orders but I would rather follow a procedure that has worked for someone else. Then at least I know it should work and it is worth persisting with.
help!
ben
Reply #3 on:
08 October, 2015, 10:48:36 AM »
Hi Frank
I agree with Brian that it is best to remove the anti-roll bar completely.
Fit the strut to the top of its tunnel and have it dangling without the hub attatched at this initial stage.
With the track control arm loosely bolted to the tie rod fit the inner end into its location on the chassis (so that the bolt you are struggling with can be easily inserted) and insert the tie rod with its various washers and rubber "cushions" into its location at the front of the wheel arch at the same time. I am pretty sure that was how I did mine when I had the gear box off to replace the core-plug that is hiding behind the flywheel.
The hub unit can then be fitted on to the drive shaft and the bottom swivel taper joint connected.
Finally the hub is connected to the bottom of the strut with the two fore and aft bolts.
I am afraid this is all from what is these days a rather poor memory but hopefully it will help.
Ben
Reply #4 on:
08 October, 2015, 10:19:47 PM »
Thanks Ben. I will give that a go.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
