Kevinlincs
« Reply #270 on: 13 November, 2018, 10:15:14 PM » |
The bonnet was in great shape, or so I thought....
Flavia 815 coupe Delta integrale
Kevinlincs
« Reply #271 on: 13 November, 2018, 10:16:42 PM » |
With the hinge off and the scab attacked with a knotted wheel a nice hole soon formed...
Kevinlincs
« Reply #272 on: 13 November, 2018, 10:18:02 PM » |
Skin cut off, reinforcer cleaned, new patch waiting to go in.
Kevinlincs
« Reply #273 on: 13 November, 2018, 10:19:29 PM » |
Bolts fitted into the hinge mount points to make sure it doesn't move, don't want to be covering up the bolt holes!
Kevinlincs
« Reply #274 on: 13 November, 2018, 10:20:22 PM » |
And smoothed off
Kevinlincs
« Reply #275 on: 13 November, 2018, 10:24:45 PM » |
So I could paint the front wings without laying them down which I didn't want to do so I could paint around the edges etc I made up these simple stands, just some spare angle attached to a brake drum for a base then the little arms at the top are adjustable to suit differing mounting holes so I can use them again in the future.
Kevinlincs
« Reply #276 on: 13 November, 2018, 10:26:35 PM » |
Wing mounts like this...
Kevinlincs
« Reply #277 on: 13 November, 2018, 10:27:19 PM » |
Which allows lovely access for painting
« Reply #278 on: 14 November, 2018, 11:48:57 AM » |
My favourite is the roof photo. It really has come out well... I expect you were as nervous as you were excited to see it in colour and reflected and to see how well you'd done. Judgement day!!!
« Reply #279 on: 14 November, 2018, 12:10:53 PM » |
The wing stand looks as though it would be unstable but I can't imagine you making anything like that. How far can it tilt before it overbalances?
Kevinlincs
« Reply #280 on: 14 November, 2018, 10:35:00 PM » |
Only a small step in reality David but a huge psychological hurdle overcome, it really does feel like you're on the home straight when the paint goes on....relity is though there's stilla huge amount to do! Repairs have come out well yes, roof amongst them
Kevinlincs
« Reply #281 on: 14 November, 2018, 10:37:03 PM » |
It is a lot more stable then it looks Frank, amazingly so really. The brake disc sits flat to the floor and is quite a large diameter one with a lot of heavy mass, takes quite a bit to try and knock it over. Only issue I found though is my use of angle steel for the stem, when you spray the wing the frame tends to oscillate!
Rob
« Reply #282 on: 15 November, 2018, 11:40:43 PM » |
I have to hand it to you Kev the shell was looking spot on after you'd finished all the repairs & now that you've laid down a few coats of Monza Rosso it looks factory fresh! You must be chuffed .
Rob MacFarlane
1988 Delta HF turbo ie 2000 Fiat Coupe 20v 1987 VW T25 Camper
Kevinlincs
« Reply #283 on: 24 December, 2018, 04:10:56 PM » |
Yep, chuffed Rob that's for sure! Sorry for the delay in replying but I have now almost caught up with where I'm at with the car, but I'll elaborate a bit more on here from the magazine articles, make a break from the Christmas talk!
The remaining panels got painted red, a while back now it seems but was really only in October I'd guess..
Hatchback I needed to paint the inside as well as outside so hanging it form the roof seemed the best solution.
Kevinlincs
« Reply #284 on: 24 December, 2018, 04:12:01 PM » |
So the inside could get painted without any masking lines, along the top inside and out too.
