Andy if the part is still available from fiat (iper should say....) then someone like Tanc Barrett should be able to order it for you from Italy.
Google search showed some russian sites carrying it.....
Andy,
Item No 9 has a circle with a line through it which means no longer serviced, but if you click the part number when in eper (it doesn't work using the photocopy!) it should show the part that replaced it if one is available, it should also show the other models in Lancia/Fiat that it was also used on.
Just been into eper and it shows as no replacement available, why not try a Fiat Dealer and ask them to search by part number there might be something left in the system, or ask can a query be raised to see if anyone still has one on the Continent.
8227
