08 August, 2022, 02:18:59 PM *
Author Topic: Series 3 LHD Up close & personal  (Read 2075 times)
John B
« on: 06 December, 2014, 03:57:21 PM »
Some pics for Simon and anyone else of course.
Simon - if you want anything specific please let me know.
(5 more pics to follow in next post)
1961 Appia S3
1969 Fiat 850 Special
John B
« Reply #1 on: 06 December, 2014, 04:01:05 PM »
........continued
1961 Appia S3
« Reply #2 on: 06 December, 2014, 05:36:49 PM »
Lovely unmolested engine bay ! New clutch - or just a very clean 'box ?
Amilcar CGS, Aprilia Cabrio, S2Aprilia, Ardea camioncino, S2 camioncino, S2 furgoncino, R4 Sinpar, R4 Rodeo, 65 Moke, R60 Tractor, R60 S, Toselli 78, Moto Guzzi Ercole, Disco 3, Mini ALL4 JCW, Moto Guzzi Cardellino, Fulvia GT, RE Himalayan, Ypsilon
John B
« Reply #3 on: 06 December, 2014, 06:17:25 PM »
Clutch was replaced just before I bought the car, also the prop shaft couplings were replaced and
all brakes renewed.
The first problem I had was the wobbly dynamo syndrome, managed to improve it a lot but still  slightly
out of alignment.
The water pump was noisy but a few squirts of grease improved that - a job for the future is to strip it out and
see if I can just replace the bearings.
There is no thermostat in the cooling system but I think this is deliberate to help combat the high summer temperatures,
my Fiat 850 Special  was the same although I have fitted one to that as it will be getting a bit of winter use so a working heater will be nice.
1961 Appia S3
chugga boom
Non-LMC Seller
« Reply #4 on: 06 December, 2014, 07:32:59 PM »
all brakes renewed.
out of alignment.
We machine a steel sleeve , from memory 10mm o/d 8mm I/d , ream the original pivot point out straight and press the insert in place , did my s2 last with engine in the car , removed the radiator and there was enough room to work , common fault on appia's and if left wears the alloy pulley's on dynamo and cooling fan , if you want to you can make 2 sleeve's so that the timing chest cover will separate easier , however make sure they are reamed out bolted together so they align correctly
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
Page created in 0.039 seconds with 21 queries.
