23 April, 2024, 07:20:57 PM *
Pages: 1 ... 31 32 33 34 35 [36] 37 38 39 40 41 ... 54   Go Down
Author Topic: Story so far series 1 resto  (Read 308898 times)
lancianut666
Slow but rough
« Reply #525 on: 13 June, 2018, 05:53:32 PM »
Meanwhile back in Hartlepool I decided to give my angle grinder something to do so set to on the wheel arches...one side had the spikiest underseal I have seen...chipping it off revealed the original green paint...pity whoever did it never saw fit to do any other parts of the car.
Clarkey
lancianut666
Slow but rough
« Reply #526 on: 15 June, 2018, 11:12:16 AM »
Hi all
little bit more done towards testing the engine...I raided B & Q's parts bins for a couple of pipe elbows and a reducer to be able to make a circuit for the cooling system I might fit the heater in as well to give us a bit more capacity. A trip to Driffield provided a +ve battery terminal so I could complete the starter wiring a quick test has the engine whizzing over nicely. I still need to wire up the temperature gauge, fill the sump with nice fresh oil, fill the radiator with some clean water and antifreeze, jury rig a fuel tank and we should be ready. I will recheck the timing before all this.
Clarkey
« Reply #527 on: 15 June, 2018, 11:34:08 AM »
Can you do a youtube video as well ?? Looking forward to hearing/seeing it run !
Good luck
lancianut666
Slow but rough
« Reply #528 on: 15 June, 2018, 11:38:44 AM »
I will probably rope El Tel in to use his considerable bulk to hold the thing down if it starts so a video is possible...will probably be next week now as all the little fiddly bits I need are of course in the unit at Hartlepool
« Reply #529 on: 15 June, 2018, 01:39:48 PM »
Sandbags over the stand legs?   Anything you could ratchet strap it to?
lancianut666
Slow but rough
« Reply #530 on: 15 June, 2018, 05:20:50 PM »
Possibly drape a couple of 3 x 2 paving stones over the engine stand bottom frame?
JohnMillham
« Reply #531 on: 16 June, 2018, 03:41:24 PM »
I would bolt it to the concrete floor.
« Reply #532 on: 16 June, 2018, 04:23:15 PM »
Is there a garage you can wheel it into with a roof truss or RSJ to semi suspend it from?
« Reply #533 on: 16 June, 2018, 04:52:15 PM »
Don used to start them sitting on the floor - it should be a smooth runner !!
lancianut666
Slow but rough
« Reply #534 on: 23 June, 2018, 04:03:24 PM »
man in a tent has got some oil pressure and wired the temperature gauge in but it gives fsd unless the case is earthed....oil pressure by the gauge is just over 35psi cranked rather slowly on the starter motor...checked for a spark and we have one...just the fuel and water now...no oil leaks as such so looking good. see before and after pics of oil pressure
Clarkey
lancianut666
Slow but rough
« Reply #535 on: 23 July, 2018, 08:12:03 AM »
Man in tent has abandoned tent for nice new garage
lancianut666
Slow but rough
« Reply #536 on: 10 September, 2018, 06:53:57 PM »
Will try to get the gearbox brought through later this week and connect it up to the engine ready to go back in the car
« Reply #537 on: 10 September, 2018, 09:01:53 PM »
You'll need some big brackets if you are going to test run it on a bicycle.
« Reply #538 on: 10 September, 2018, 09:15:16 PM »
Ha ha Frank, very good!
8227
lancianut666
Slow but rough
« Reply #539 on: 20 September, 2018, 06:40:34 PM »
Hi all
good day yesterday as we got the car down to his new home...big thanks to Darren our wagon driver as he was simply the best in very scary conditions with the very high winds...
Clarkey
Pages: 1 ... 31 32 33 34 35 [36] 37 38 39 40 41 ... 54   Go Up
Page created in 0.089 seconds with 21 queries.
