dannels
« on: 30 March, 2014, 06:10:11 PM » |
Hi All,
Looking for the plastic 3 blade fan (if it has a working motor attached to it, its a bonus) that sits in the cold air intakes for the heater. From the manuals it looks like the same item for both Flavia and Flaminia
Many thanks
Dave
1961 Flaminia GT, 1966 Matra Djet V
« Reply #1 on: 30 March, 2014, 06:47:53 PM » |
Do you have a photo and dimensions ? May be the same as a third ser. Appia
Jay
« Reply #2 on: 31 March, 2014, 09:53:39 AM » |
Hi Dave
Did you manage to source a different motor, as mine although they do occasionally work they are reluctant to spin after sitting for some time.
If you haven’t got one to measure / photo, one of mine is out the car at the moment so could take a picture of that.
Thanks Jay
Julian Wood, Kingston, London
« Reply #3 on: 31 March, 2014, 04:42:44 PM » |
This is the Appia one - approx 11cm in diametre. If it is the same , it will probably be easier to find one from an Appia rather than a Flaminia fan
Jay
« Reply #4 on: 31 March, 2014, 08:23:52 PM » |
That looks very similar even the motor and the way it's mounted on 3 rubber blocks and a couple of pins per block from the outside of the housing. I have tried to remove the fan but the slot head just won't move.
Now I need to source at least one motor and may be fan.
« Reply #5 on: 01 April, 2014, 12:31:19 AM » |
It also looks the same fan but not the housing as in Series 1 Fulvia Berlina, I've got a spare in the loft so if you still need one I'll have a closer look. Brian 8227
Jay
« Reply #6 on: 01 April, 2014, 07:23:11 AM » |
Hi Brain
I don’t to jump on Dave’s thread, as know he needs a fan (may be a motor), but if he is sorted, then I be interested in the motor if they are the same as flaminias.
Also a copy of the Girling Dunlop Brake Catalogue would be appreciated, as my breaks have been earmarked for an overhaul this autumn.
thanks
Jay
« Reply #7 on: 01 April, 2014, 08:34:55 AM » |
Hi Brain I don’t to jump on Dave’s thread, as know he needs a fan (may be a motor), but if he is sorted, then I be interested in the motor if they are the same as flaminias. Also a copy of the Girling Dunlop Brake Catalogue would be appreciated, as my breaks have been earmarked for an overhaul this autumn. thanks Jay Hi Jay, I'll see if I can have a look at the fan today. Can you pm me your address and I'll burn and send you a copy of the Girling/dunlop catalogue. Brian 8227
dannels
« Reply #8 on: 01 April, 2014, 12:36:03 PM » |
Yep still looking. The appia fan is exactly the same - so if anyone has one spare???
Cheers Dave
« Reply #9 on: 01 April, 2014, 03:40:46 PM » |
Cheers Dave
Checked my spare Fulvia Berlina fan and it's abouit 4.1/2" which is somewhere around what you're looking for, I've checked the motor and it works but it is riveted to tube not screwed. Brian 8227
Jay
« Reply #10 on: 01 April, 2014, 04:20:23 PM » |
Hi Brian
That looks the part, not sure about the length of the blades, although they do look about the same. As I mentioned I don’t won’t to step on Dave’s toes, but if it’s going spare I drop you a PM.
Jay
« Reply #11 on: 02 April, 2014, 07:41:50 AM » |
Hi Brian
Jay
Dave/Jay I meant to point out the fan blades are aluminum not plastic. Dave as you asked first you have first refusal, can you let me know if you're still interested, if not it goes to Jay. Brian 8227
dannels
« Reply #12 on: 03 April, 2014, 12:05:54 PM » |
I am Brian - just PM'd you!
Many thanks Dave
« Reply #13 on: 03 April, 2014, 10:52:18 PM » |
Many thanks Dave
Dave, I've just replied. brian 8227
dannels
« Reply #14 on: 12 April, 2014, 02:31:04 PM » |
Many thanks Brian - just fitted it - works perfectly
It was an absolute pleasure to take a spin in Fay - it's a credit to you! Can wait to get mine running now....
Cheers Dave
