26 April, 2024, 04:16:50 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Buy, Sell and Search
Spares required
Flavia Hydrovac brake servo required
Pages: [
1
Go Down
« previous
next »
Author
Topic: Flavia Hydrovac brake servo required (Read 2761 times)
phil-m
on:
04 January, 2013, 04:37:44 PM »
Does anyone have an old Flavia remote servo for sale, the remote Hydrovac type. Mine has developed a bit of a habit for brake fluid so I would like to rebuild another and then swap them over. Any advice on rebuilding would also be greatfuly accepted.
Re: Flavia Hydrovac brake servo required
Reply #1 on:
04 January, 2013, 06:40:21 PM »
Consortium sell an after-market replacement and Omicron renovate if that helps. It is a weird system - I have just got a Flavia Vig and am going through it before the MOT. I bled the brakes in the normal way without realising you should first start at the slave cylinder. Anyway seemed to be OK and changed the fluid and got the air out.....
1998 Zeta 21. 12v
ColinMarr
Reply #2 on:
14 January, 2013, 08:49:46 PM »
Phil,
I missed this question when you first raised it – sorry. The remote servo fitted to Flavia and Flaminia earned a poor reputation for unreliability, but in my experience a lot of this was unfounded. I successfully rebuilt the servo for my car in the mid 1980s and went on to do two more for others. The system is only marginally more complicated than the dual circuit master-cylinders fitted to Flavia and Fulvia – it you are OK with that then doing the servo should be no more problematic.
The most common fault was brake fluid getting past the seals at the vacuum chamber end of the unit, into the chamber and then into the inlet tract with lots of white smoke in the exhaust to prove it!
One of the problems then was the lack of seals. Rebuild kits were not available in the UK and at least two of the cup seals seemed to be almost unique to this system. I searched through the parts bins of a motor factor that was supposedly a Lockheed agent and I found cup seals that did the job, others were simple ‘o’ rings that were easy to obtain.
Another problem was that the design of this system involved a side-shoot from the main cylinder going off at an angle (and hence blind) to the air filter, so that it was impossible to push the piston out with a wooden dowel. The trick (leaned from the wizard Tony Amato) was to tap the flange end of the side-tube with a pin-hammer until low-and-behold the piston with its ‘o’ ring rises up out of the housing until you can grip it to pull it out. Any slight damage to the flange needs to be flattened out.
Cleaning up the bores with very fine abrasive paper, fitting new seals and putting it all back together seemed to complete the job.
Of course, you may now find an alternative remote unit off the shelf, but when I did it that wasn't an option.
Good luck!
Colin
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
Model Technical and Interest
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
