28 March, 2024, 10:17:48 PM *
Pages: 1 ... 15 16 17 18 19 [20] 21 22 23 24 25 ... 30   Go Down
Author Topic: flaminia  (Read 214328 times)
Richard Fridd
« Reply #285 on: 02 January, 2017, 08:50:00 AM »
A year gone by already!! For Flavia (in Mkg) 30 front and 20 rear? (From consortium 'torque settings' list. Not sure why the difference front and rear.
lanciab20
President
« Reply #286 on: 17 January, 2017, 05:31:38 PM »
I have not seen the style of airfilter on p110, but am reminded as I look at it of the howler in this roadtest on p111;  "Suspension remains unchanged from the Aurelia.  Coil springs and wishbones support the front end...."  Oops.
Richard Fridd
« Reply #287 on: 25 June, 2017, 05:45:12 PM »
I would like to fit the correct windscreen wipers. Can anyone here tell me the correct make and length. And if anyone has a pair spare, perhaps I could buy them. Richard 07957292127
Richard Fridd
« Reply #288 on: 16 April, 2019, 04:39:25 PM »
Hopefully the wipers currently for sale on this forum will be OK
pchflyer
« Reply #289 on: 14 May, 2019, 04:22:33 AM »
Hi Richard, you might be interested in my experience with the brakes in my Flaminia. The servo had been overhauled by Omicron shortly before I bought the car but I was never that happy with the way the car stopped.  After discussing with other owners, a story of the unreliability of the Flaminia servo emerged.  In particular, David Wakefield told me that he had experienced repeated problems until he finally upgraded to a modern servo.  I decided to follow his example.  There are not that many dual circuit remote servos being made today but Frenos Iruna in Spain do one (available from S-V-C in UK) for about £300 which is less than half the cost of getting the original overhauled. I made up a couple of mounting brackets that used the original mounting points and installed the new unit with no trouble - see picture - except that I had to fit a hydraulic brake light switch as the new unit (unlike the original) does not incorporate one.  Result - the car now stops like a modern car and the performance can be exploited with no worries about stopping.  More important, the unit has been totally reliable.
This servo is available again through S-V-C, although in an updated form. I just received it and it's at the mechanics'. It seems obvious, but can you confirm that the forward cylinder (to the front of the car) is for the front brake circuit?
Edit: I Just heard from supplier- they say either side can go to either circuit.
« Last Edit: 14 May, 2019, 05:56:04 PM by pchflyer » Logged
Richard Fridd
« Reply #290 on: 23 May, 2019, 05:03:40 PM »
Can anyone here identify this Flaminia trim part from my store? Advice welcome
dannels
« Reply #291 on: 01 July, 2019, 06:15:10 PM »
I've no idea - but I'll take a punt....
Does that circular 'bulge' cover the mounting on the floor for the chassis leg perhaps?
1961 Flaminia GT, 1966 Matra Djet V
Richard Fridd
« Reply #292 on: 06 September, 2019, 07:23:36 AM »
.        I will have a look next time I am at the garage. In the meantime I have been given a half hide to repair the drivers seat. The passenger seat has been restitched and now needs some extra padding
Richard Fridd
« Reply #293 on: 06 September, 2019, 08:02:19 AM »
Quite a good colour match and dyed all the way through.
Richard Fridd
« Reply #294 on: 10 September, 2019, 07:02:23 AM »
.       Refitting the passenger front seat squab has revealed the mystery trim item to be a cover for the drivers seat lower rear area
Richard Fridd
« Reply #295 on: 17 September, 2019, 02:32:45 PM »
Driver's squab now reupholstered. A good qualit job, and swift return
williamcorke
B10
« Reply #296 on: 17 September, 2019, 04:10:08 PM »
Lovely work Richard.
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
'55 Giulietta Sprint
S1 Land Rover
Richard Fridd
« Reply #297 on: 20 September, 2019, 05:00:27 PM »
Thanks William. The next job is to improve the smokey exhaust. Does anyone here know if the pistons can be withdrawn from the bottom end without fouling the crankshaft? I would like to inspect the oil control rings. Compression is equal and good, so oil rings or valve guides perhaps?
« Last Edit: 24 September, 2019, 04:05:41 AM by Richard Fridd » Logged
Flamfan
« Reply #298 on: 22 September, 2019, 01:46:24 PM »
Is your exhaust smokey on start up with choke or all of the time with choke off ?
Black smoke or blue ?
Is it worse under fierce acceleration ( seen in the rear view mirror ) ?
Richard Fridd
« Reply #299 on: 22 September, 2019, 03:13:22 PM »
Black/grey mist all of the time and black/grey smoke when under load, ie when pulling away going uphill
Pages: 1 ... 15 16 17 18 19 [20] 21 22 23 24 25 ... 30   Go Up
