sparehead3
« on: 17 February, 2011, 12:22:56 PM » |
Hi All, From Ade: "I don't know if it's just me, but since the update I have been having problems using the 'Show unread posts since last visit' feature. Some of the time it will show the list, then if I start to read topics the next time I go back to it there are no unread posts to view. Some times although there are unread topics the list is empty." Has anyone else experienced this ? I'm fine on a Windows7/IE8 setup and an XP/IE7 setup. Ade is on Vista and Windows7 and gets this problem. I'm check out the Forum Forums  *checking on the Forum Forums I can only find references to fixes and not to problems ....
« Last Edit: 17 February, 2011, 12:27:17 PM by sparehead3 »
« Reply #1 on: 17 February, 2011, 01:38:08 PM » |
Don't know if we're talking about the same thing, but if I've only read halfway through the unread posts and then have to go out of the forum, next time I come back in, maybe only minutes later, all the unread posts are gone and the only way to find them is to go through the forum looking at the latest date of posting in each subject. It's nothing new, I've always had this problem and found it frustrating. Briab 8227
Own 1966 Fulvia 2C Berlina since 1997, back on road 11-1999.Known as "Fay" 1999 Suzuki Wagon R+ GL, now my daughters 2006 Renault Megane 1 5 Dci Sports Tourer Dedra Technical Adviser
« Reply #2 on: 17 February, 2011, 01:47:30 PM » |
Brian, I have the same problem as you, (the one where you 'lose' some unread messages), but it was easily remedied once I had discovered the 'show all unread posts' option !!! An excellent device.
However, I also have found that on occasion I find in the 'unread posts' messages that I have definitely read before. Most confusing, is it the system, or simply me being a plonker !!!
sparehead3
« Reply #3 on: 17 February, 2011, 10:48:07 PM » |
Ok , it's maybe not Ade , but also maybe not the update to the system either ! See if we can nail it down ... unfortunately I don't remember having any problems !
« Reply #4 on: 17 February, 2011, 11:23:11 PM » |
Thanks Andrew, Pleased it's not just me! Steve, thank you. Brian 8227
stuwilson128
Non-LMC Seller
« Reply #5 on: 18 February, 2011, 08:25:04 PM » |
Don't know if we're talking about the same thing, but if I've only read halfway through the unread posts and then have to go out of the forum, next time I come back in, maybe only minutes later, all the unread posts are gone and the only way to find them is to go through the forum looking at the latest date of posting in each subject. It's nothing new, I've always had this problem and found it frustrating. If you open the unread posts page and then navigate away from the forum, the software will assume that you have read all of the posts which were new. Effectively, by opening the unread posts page, all new posts at that point are flagged as having been read as far as the new posts page is concerned. Therefore, when you return to the forum it will say that there are no new posts even if you have unread posts (Note the difference between new posts and unread posts). My suggestion to overcome this problem is to set you browser to have 2 home pages with the forum being one of them. This will open the forum and your other homepage / search engine in two separate tabs, so if you need to do something away from the forum, you just select the other tab rather than navigating away from the forum. This is what I do and I always have the forum open. It also refreshes the forum each time you press the homepage button. Hope this helps!
Stuart Wilson 11175 1973 Fulvia Coupe 1.3 2000 Lybra SW 2.4JTd 2009 Delta 1.9 Twin Turbo
« Reply #6 on: 19 February, 2011, 12:52:14 AM » |
Don't know if we're talking about the same thing, but if I've only read halfway through the unread posts and then have to go out of the forum, next time I come back in, maybe only minutes later, all the unread posts are gone and the only way to find them is to go through the forum looking at the latest date of posting in each subject. It's nothing new, I've always had this problem and found it frustrating. If you open the unread posts page and then navigate away from the forum, the software will assume that you have read all of the posts which were new. Effectively, by opening the unread posts page, all new posts at that point are flagged as having been read as far as the new posts page is concerned. Therefore, when you return to the forum it will say that there are no new posts even if you have unread posts (Note the difference between new posts and unread posts). My suggestion to overcome this problem is to set you browser to have 2 home pages with the forum being one of them. This will open the forum and your other homepage / search engine in two separate tabs, so if you need to do something away from the forum, you just select the other tab rather than navigating away from the forum. This is what I do and I always have the forum open. It also refreshes the forum each time you press the homepage button. Hope this helps! Thanks Stuart, would be nice to have a box you ticked when you'd read the the post  but I'll try your way. Brian 8227
« Reply #7 on: 19 February, 2011, 09:12:52 AM » |
I thought it was always like Stuart said???
Its not the winning but taking part! or is it taking apart? 1955 Aurelia B12 1967 Flavia Vignale iniezione 1967 Fulvia 1.3HFR 1972 Fulvia 1600HF 1972 Fulvia 1600HF 1972 1600 Fulvia Sport 1979 2500 Gamma Coupe 1988 Delta 1.6GTi 1998 Zeta
nyssa7
« Reply #8 on: 03 March, 2011, 09:21:55 PM » |
Has never worked for me - always get the message "no unread messages" despite never logging out of the site
Strangely enough, if I access the forum from an email notification, it works perfectly - so now I only ever access the site wne someone spots a Lancia on the road. Sometimes I have weeks of posts to catch up with
2000 kappa coupe 20vt 1996 kappa saloon 20vt race car the "Yntegrale" 1999 Lotus Elise S1 2016 Mercedes CLA45 Shooting Break
Y10 Advisor
Dilambdaman
« Reply #9 on: 04 March, 2011, 12:08:22 AM » |
Same for me. Robin.
Robin Lacey 3222
1932 Dilambda 1969 Fulvia S1 1.6HF Fanalone
Dilambdaman
« Reply #11 on: 04 March, 2011, 10:42:14 PM » |
Many thanks Steve but no change, it still won't work for me.
However, no big deal as I've got used to getting round the problem.
Robin.
Robin Lacey 3222
neil-yaj396
« Reply #12 on: 05 March, 2011, 10:50:52 AM » |
Randomly last week I had no unread messages when the forum clearly showed quite a few. It's been ok since though.
