18 September, 2024, 11:28:52 AM *
Author Topic: Part numbers for Ducellier ignition bits?  (Read 6721 times)
zagatoman
Looking a lot better
« on: 26 August, 2010, 10:12:17 AM »
Hi all, just want to pick your brains again.
Can anyone please supply me with part numbers for Ducellier ignition bits for a 1968 Fulvia Zagato 1300cc
Points
Condenser
Rotor arm
Cap.
Alternatively, has anyone got a Marelli distributor for a 1300cc Fulvia Sport Zagato they don’t want?
Thanks, Paul
Series 1, 1.3 Fulvia Zagato 1969
« Reply #1 on: 26 August, 2010, 02:15:35 PM »
You could check for a Luminition convertion....
zagatoman
« Reply #2 on: 26 August, 2010, 06:19:28 PM »
Hi Tim,
Funds are short so will have to go with the Marelli distributor if I cant get the Ducellier ignition bits.
Would be nice though.
Paul
nistri
« Reply #3 on: 27 August, 2010, 06:57:26 AM »
I might have a new Ducellier distributor among my spares. I will check it at the weekend and will let you know if available. Regards, Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
zagatoman
« Reply #4 on: 27 August, 2010, 11:54:30 AM »
Hi Andrea,
thanks for the offering to look for the Ducellier distributor, I actually need a Marelli distributor. The problem is I cant find ignition parts for my car with the Ducellier distributor so have decided to fit a Marelli distributor that I can get parts for.
I would still like to use my Ducellier distributor, would you have and ignition parts for this?
Thanks again, Paul
nistri
« Reply #5 on: 30 August, 2010, 11:00:54 AM »
Hi Paul,
I do have a Ducellier distributor complete but used and in good conditions. I can send you a couple of photos if you give me your e-mail address (they are quite large). The type of Ducellier I have is 4206A. I am not sure what the exact problem with your distributor is (apart from scarcity of spares). Nonetheless, I think that the same distributor was fitted to a range of French cars of the 60s. Have you tried to cross reference it to Renault and Peugeot? From distant memory, I think this one uses a rotor arm which was very similar to the one of my Renault 12.
Marelli distributors: with four Fulvias at home I regrettably cannot risk parting with any.
Best regards, Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
Nigel Carine
« Reply #6 on: 31 August, 2010, 03:18:50 PM »
Hello Paul
To take Andrea's idea a bit further< I run an Alpine Renault and have no problems getting bits for the Ducellier. Try a firm called Meca Parts (good website) or GBS (not so good), both Renault dedicated.. You will need the number on the side of the dizzy and they are French so postage will be heavy but worth a try if you're desperate.
lanciab20
President
« Reply #7 on: 06 September, 2010, 04:02:25 PM »
Have you tried
http://www.ignitioncarparts.co.uk?
They do some Beta stuff, Dedra, A112, Thema, nothing listed for Fulvia but they might be able to get you a number.
Page created in 0.054 seconds with 20 queries.
