20 April, 2024, 01:40:17 PM *
Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Living with a Trevi  (Read 52204 times)
St Volumex
Owner of RetroPart
« Reply #45 on: 04 June, 2013, 09:03:45 AM »
Theo, your Trevi tribulations made me smile - typical of trying to live with any 'historic vehicle'.  I know whereof you speak.  Grin
You may want to check the vacuum pipe from the intake manifold to the brake servo, which can sometimes crack.  Huh?
Guy McDougall
www.facebook.com/RetroPart
Rare Parts for Rare Machines
Thotos
Theo Kyriacou
« Reply #46 on: 04 June, 2013, 09:54:32 AM »
Yes the pipe was old and cracking and was replaced ages ago.
The brake problem was due to the master cylinder which I replaced a year ago before the MOT. And I used time and gravity to bleed the system!  Wink I replaced the master cylinder, used a piece of wood and a brick to keep the brake pedal pressed all the way down and walked away for a week and when I got back in the car the brakes worked perfectly with a lovely solid feel to the pedal  Cheesy Grin
Theo Kyriacou
St Volumex
Owner of RetroPart
« Reply #47 on: 04 June, 2013, 10:44:15 AM »
Archimedes would be proud of you Theo!  Grin
Guy McDougall
Thotos
Theo Kyriacou
« Reply #48 on: 04 June, 2013, 11:13:41 AM »
 Wink Cheesy Grin Grin Grin Grin
Theo Kyriacou
« Reply #49 on: 04 June, 2013, 11:37:49 AM »
How did the brake fluid stay in the master cylinder and not all over the floor. A Fulvia takes c 1 day by gravity.....to lose all its fluid Angry
Thotos
Theo Kyriacou
« Reply #50 on: 04 June, 2013, 12:30:20 PM »
Well, that just shows how good a car the Trevi is!  Grin Grin
Incidentally, the Trevi has the same master cylinder as a Gamma which costs about four times as any other master cylinder  Embarrassed Certainly four times as much as a Fiat 131 master cylinder  Undecided
Theo Kyriacou
Thotos
Theo Kyriacou
« Reply #51 on: 02 July, 2013, 10:56:04 AM »
Nearly there  Cheesy The bottom of the doors needed quite a bit of reconstruction  Undecided  but it's all done now  Cheesy and there's paint which actually shines on the car  Grin  Just needs to be put back together and then it's up to me to sort out the interior .....
Theo Kyriacou
« Reply #52 on: 02 July, 2013, 11:52:19 AM »
Reading back I saw the expansion tank.  Any luck sourcing better?
I recently cleaned a similar one up for a Fiat Strada with a brush backed sander and was able to cut through the impregnated dirt to a clean surface below and get a pleasing satin finish.  There's enough control to leave text and other detail in place.  A brush backed sander is quite an exotic thing (I had it for woodworking) but a similar tool is a webrax flap wheel like this:
http://www.abtec4abrasives.com/flexclean-flap-wheels-spindle-mounted-129-c.asp
Thotos
Theo Kyriacou
« Reply #53 on: 03 July, 2013, 09:44:02 AM »
I managed to get a good used one.
The problem wasn't dirt (the picture of the dirty one was one I found for sale on ebay) but leaking due to cracking. Apparently it's a common problem with these; they crack round the central 'support' and it's impossible to glue them effectively.
Theo Kyriacou
« Reply #54 on: 03 July, 2013, 10:43:55 AM »
Would have been a shame to have to go all tig-welded ali and blue hoses under there.  Perhaps strip lights down each side of the engine to show it all off as well Smiley
Thotos
Theo Kyriacou
« Reply #55 on: 03 July, 2013, 11:44:48 AM »
Getting there ...  Cheesy
Theo Kyriacou
« Reply #56 on: 03 July, 2013, 02:05:51 PM »
Looking nice ! There can't be too many left in the UK ?
We had a couple of Trevis and I loved the dash .......
Thotos
Theo Kyriacou
« Reply #57 on: 09 July, 2013, 09:39:15 AM »
Nearly there...   Grin
New windscreen (the last one in the country apparently!) was fitted last Friday and only finishing touches left now  Cheesy
Should be coming back home on Friday  Cheesy
Theo Kyriacou
« Reply #58 on: 09 July, 2013, 09:41:57 AM »
With a top tint no less!!
Now what's the car in the background...
Thotos
Theo Kyriacou
« Reply #59 on: 09 July, 2013, 09:42:35 AM »
Four of them in the UK of which two are in regular-ish use and only one, mine  Wink  is an automatic. But with over 60,000 miles on the clock I'm not sure how long the automatic gearbox will last, they're only good for 60,000 miles apparently  Undecided
Theo Kyriacou
Pages: 1 2 3 [4] 5 6 7   Go Up
