Bit late reading this one.
For me, number 1 is a Smartphone followed by breakdown cover and then in the boot fan belt(s) , points, fuel filter (only if there is any doubt about the condition of the tank) , fuel pipe, fuses, bulbs, water, oil, brake fluid and windscreen washer fluid with possibly a spare wiper blade in winter. Assuming you have a 'travelling' tool kit ensure you have some wire ( strong enough to replace an exhaust bracket say. . Beyond that there is a rule that says that if for example you carry a spare dynamo, your dynamo will NEVER play up when you are away.
Bon voyage.
As Chris says be prepared, and have a good checkover before you go, and chances are if youve got it, your unlikey to need it!.
No doubt as many others have, I've been prepared/lucky, or whatever you like to call it, over the last 20 years I've driven many miles on the Continent, and the worst that has happened was a puncture in Portugal when I hit a pot hole, 5 up on the way to a dinner.
A few more problems at home, but I've only come home once on the back of an AA wagon, after blowing a recently replaced head gasket .
8227
![Cool](http://www.lancia.myzen.co.uk/forum/Smileys/default/cool.gif)
