theoldsmithy
« on: 23 August, 2023, 10:13:57 PM » |
Hi all
Seems my NSR hub is worn internally such that a replacement bearing is not a tight fit and I can still feel (& more importantly the MoT man can feel) slight play. Does anyone know where I might find such an item? Not sure who breaks them these days, most places I knew seem to have gone.
Thanks for any help
Michael Smith 1987 Delta HF4WD 2012 Delta 1.4 SR 2012 Ypsilon 0.9 Limited
Kevinlincs
« Reply #1 on: 23 August, 2023, 10:45:22 PM » |
I'd say Tanc Barrett will have some, not the sort of things that flies off the shelf.
Flavia 815 coupe Dedra turbo Delta integrale
theoldsmithy
« Reply #2 on: 24 August, 2023, 04:02:17 PM » |
Thanks, they are looking into it but not sure if they have any. If they do, not sure if they'd sell one.
GREENYORKIE
« Reply #3 on: 26 August, 2023, 10:11:32 PM » |
Have a look on the Zagato lancia website.They have them listed as reconditioned items but want an email enquiry.Otherwise you may need to find a machine shop who can sleeve the housing. Best of luck. David
Evo1 1992, Delta HPE HF 1998, Beta coupe 2000,1983.Audi TT. Delta HF Turbo,1988.
theoldsmithy
« Reply #4 on: 28 August, 2023, 10:04:38 AM » |
Thanks, yes I’ve emailed Zagato but there’s been zero response so far. If I’m honest, the answer phone message they have is so bad quality & the website so dated I’m not entirely sure they’re still going.
GREENYORKIE
« Reply #5 on: 09 September, 2023, 10:48:20 PM » |
Any luck in resolving your problem?
theoldsmithy
« Reply #6 on: 10 September, 2023, 03:03:00 PM » |
Despite phoning Tanc & them saying they'd check, I've heard nothing since. I also emailed them & sent a message on their website, but zero response. An employee of Deltaworks emailed to say they couldn't find one. Finally had a slightly odd email from Zagato saying 'check integrale.org.uk' - which as you pointed out earlier, says to email them for price & availability. If you put one in the basket, it says out of stock anyway.
Pretty useless all round then.
Seems maybe I take a punt on the German 16v one on eBay (they have an ABS sensor housing in the casting which I don't think matters) & hope it's ok - £275 down the drain if it isn't. Could be I get this one sleeved, or bodge it with Belzona. Not too sure the best way to go.
« Reply #7 on: 10 September, 2023, 03:34:32 PM » |
At £275 I would go with sleeving as you know what you are starting with, also replacement may not be any better?
« Last Edit: 10 September, 2023, 09:45:10 PM by peteracs »
theoldsmithy
« Reply #8 on: 10 September, 2023, 08:07:25 PM » |
Indeed, probably best I think.
« Reply #9 on: 11 September, 2023, 06:41:01 AM » |
There are some very good loctite bearing fit products.
