24 April, 2024, 08:23:24 PM *
Pages: [1] 2   Go Down
Author Topic: Ordering sliding pillar springs  (Read 3663 times)
DavidHill
« on: 11 June, 2022, 09:36:17 AM »
Morning all,
further on my sliding pillar restoration - i plan to replace the missing main spring by getting a pair of new springs made for my front sliding pillars. My theory is that it is better to get a pair made.  I plan to ask the spring company to make two copies of the existing spring that i have, as i believe it would be better to have a pair the same.  But before i do that...does anyone have any information on the specification for the spring - as i am assuming that after 70+ years there will be some wear and deformation on the existing spring that i have??
cheers
David.
« Reply #1 on: 11 June, 2022, 10:23:40 AM »
Hi David
This info is available from the LMC library as well - can you let us know the cost of making the springs please ??
Sebastien
« Reply #2 on: 11 June, 2022, 11:10:11 AM »
Hello David,
Before manufacturing a pair, have you checked with Cavalitto in Turin if they are available?
I assume you want them for an Aprilia or an Ardea. Cavalitto manufactures frequently requested parts for those models.
And if you still want to have them manufactured, once the machine is set up, it costs almost nothing to have a few more pairs wound!
« Reply #3 on: 12 June, 2022, 06:22:33 AM »
D Faulkner near Chichester are a brilliant company ro deal with. I had a pair of custom sp springs made for my B12. No complaints.
DavidHill
« Reply #4 on: 13 June, 2022, 07:47:30 AM »
thank you Simon for the specs! i have checked cavillito's site and they do not list springs, so have contacted C Faulkner's...will keep you posted on prices..
will
« Reply #5 on: 13 June, 2022, 08:36:55 AM »
Cavillito does not always list all his parts on the website best to email him
Raahauge
« Reply #6 on: 13 June, 2022, 08:28:23 PM »
I find the problem with Cavalitto is getting a response.
« Reply #7 on: 14 June, 2022, 08:31:16 AM »
Count me in, please.
Kari
« Reply #8 on: 14 June, 2022, 10:00:00 AM »
I use e-mail: info@lanciaricambi.it and usually get response the same day.
Karl
DavidHill
« Reply #9 on: 14 June, 2022, 02:46:48 PM »
ah, good point, am checking with Enrico... meanwhile C Faulkners have a spring that very nearly matches available off the shelf.
existing spring measures as follows:
length 277mm, OD = 65mm, ID = 47mm
Faulkners spring measures (including the powder coating)
length = 279mm, OD = 66.6mm, ID = 48.2mm
with the same deflection per kg
so will see what Enrico has, but may go for the Faulkners spring as it is very close, particularly if i remove the powder coating...
Raahauge
« Reply #10 on: 15 June, 2022, 08:01:53 PM »
Thanks Kari, good tip. I mailed last night, had a reply by 7.30 this morning and have ordered some bits.
I had made three enquiries in the past from their 'automated' website without response.
GG
« Reply #11 on: 16 June, 2022, 11:38:48 AM »
Sometimes the response varies due to how busy he is: in the lead up to the Mille Miglia, he may well have been super busy.
« Reply #12 on: 16 June, 2022, 09:17:53 PM »
That is very tempting, David.
DavidHill
« Reply #13 on: 20 June, 2022, 08:27:57 AM »
a quick update, i had an initial reply from Enrico stating he probably had the springs, but asking for measurements...i immediately responded with measurements, but he never replied to that response (despite sending via the email address and using the webform)...so after a week of waiting i have gone for the Faulkner springs and ordered them this morning....will update on progress when the arrive.
DavidHill
« Reply #14 on: 21 June, 2022, 08:56:53 PM »
the springs arrived from Faulkners this morning, well packed and a quick service.  I have checked all the dimensions and they fit very well...my only slight worry is the top and bottom of the springs are not finished flat all round the circumference as with the originals (see pics) this leaves a small gap under the thrust bearing - i dont think that is an issue as the thrust bearing surfaces are very stiff...any thoughts??
Pages: [1] 2   Go Up
Page created in 0.068 seconds with 22 queries.
