« on: 15 May, 2022, 06:19:11 PM » |
Starting to install the new pillar/stub axle assemblies. I find I cannot remove the pillar because it fouls the frame. I am thinking I will have to remove the screwed in sleeve ("guide tube according to parts list"). Thing is, Freyja and I did this in the garage at Sacro Monte and I canot remember how we did it. The locking ring at the bottom is dam' tight. I think I may have to use a little heat after I have made a suitable spaniard to fit it.
JohnMillham
« Reply #1 on: 16 May, 2022, 07:11:06 AM » |
Yes, the sleeve has to be removed first. It will only just come out then! Good luck.
« Reply #2 on: 17 May, 2022, 04:43:50 AM » |
Thanks, John. Do they screw in or just slide in like the bottom ones?
JohnMillham
« Reply #3 on: 17 May, 2022, 07:21:52 AM » |
When the ring 101058 is undone, it will slide out.
« Reply #4 on: 17 May, 2022, 04:00:26 PM » |
101012 upwards or downwards? I removed the ring 101058, having made a tool and applied a lot of heat and force. It would have come easier if I had known about the locking pin 10721 hidden at the back which pinged out after a few turns. I have tried pulling it out using a 5mm spacer and 101014 to pull upon it, thinking it would come once it started to move. No such luck. "Slide out" is not in its vocabulary. It has shifted a couple of mm. but with great difficulty. Either I have to make a thicker spacer or install 101014 and tap it downwards. Pulling it up would seem better... I do not remember such struggles when Freyja and I did it on the other side in Sacro Monte!
JohnMillham
« Reply #5 on: 17 May, 2022, 07:07:11 PM » |
I think it slides up when the bottom ring is undone, but it was a while ago when I had mine apart, so I could be wrong. You might have to tap it a bit to persuade it.
« Reply #6 on: 18 May, 2022, 12:36:49 PM » |
Finally got it off this morning. The sleeve was so tight I had to hammer the spanner to try to extract it (using a spacer made from an old ball bearing) so I tapped it down, cleaned it all and then drew it upwards easily. When I do the other side I will take pictures and post it in the technical thread.
« Reply #7 on: 24 May, 2022, 08:09:39 PM » |
Fitting new spring thrust bearings and wondering what grease - very thick "axle grease" or moly which is thinner but higher shear. Any ideas?
JohnMillham
« Reply #8 on: 25 May, 2022, 09:50:09 AM » |
I think they live in oil. Were they not covered in oil when you removed them? If not, I suppose Moly would do the job best.
donw
« Reply #9 on: 25 May, 2022, 06:26:58 PM » |
Looking forward to seeing the"other" side before I start on mine!
Don Williamson Member 111 joined 26th July 1963 1917 Theta 2str 1926 Lambda torpedo 1930 Artena berlina 1933 Belna coupe
« Reply #10 on: 01 June, 2022, 10:45:55 AM » |
Done. Full instructions in technical information thread.
« Reply #11 on: 21 June, 2022, 07:05:11 PM » |
Whilst installing the new pillars I took advantage of the opportunity to determine the true angles (camber and castor) of the pillars themselves with the aid of a right angles bubble level and a spacer. Not the most successful photographs - I need to make an appointment with Zaphod Beeblebrock's surgeon to have an extra arm fitted.
GG
B20 s.2, Appia C10 unrestored
« Reply #12 on: 22 June, 2022, 02:21:06 PM » |
Marc Bondini, Australian Aurelia guru, found some "angle measuring gizmo" that was about 1 ½" square and magnetic, and you could just snap it onto the vertical element, and it would tell you its angle.... he got them off Amazon.....
« Reply #13 on: 23 June, 2022, 12:50:45 PM » |
Cheaper than a third arm, too.
williamcorke
B10
« Reply #14 on: 23 June, 2022, 02:20:17 PM » |
'37 Aprilia '50 B10 '53 B20 '68 Flavia Vignale '55 Giulietta Sprint S1 Land Rover
