28 April, 2024, 05:46:20 PM *
Author Topic: Throttle please!  (Read 3541 times)
ian
« on: 15 June, 2008, 10:10:34 PM »
The small triangular piece of metal and the three bolts that hold the throttle pedal to the floor pan....has any one got any good spares?
Scott
« Reply #1 on: 17 June, 2008, 07:40:46 AM »
If Omicron (http://www.omicron.uk.com/) or Cavalitto (www.oldlanciaspares.com - look at http://www.oldlanciaspares.com/imgdb/81719827.JPG) can't assist you then for such a relatively simple piece of metal fabrication it could be worth just asking a local metal shop to do the job for you if you have the original that they can base a new one on. Just a thought...
Neil Lewis
« Reply #2 on: 17 June, 2008, 10:11:26 PM »
I took that rediculous bit of rubber and metal out of my Fulvia and threw it away.  Then I welded a flat plate onto the end of the throttle rod and, hey presto, I had a throttle pedal just like every other car and one I could use without it sticking part way down (or worse, part way up).  Great for heel-and-toe too.  It stayed like that for nearly 100,000 miles when it was sold on.
Since you can now buy after-market metal pedal sets, I guess that would be my choice now.
Simply solutions are always the best :-)
Neil
ian
« Reply #3 on: 17 June, 2008, 10:40:44 PM »
I don't find the pedal a problem, just a rusty plate I would like to replace, that would (in my case) be the simplest solution if any one had one knocking about, but I take your point. I've got a bit of a young wiz doing the welding, he will make one up for me, I was just trying to make his job a bit easier Grin
ian
« Reply #4 on: 16 July, 2008, 10:50:17 PM »
young wiz made up the plate, did a nice job. not an exact copy, but will last longer than the original  Grin
