25 April, 2024, 09:45:39 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
General
General Chat
Flaminia V6 engine, single solex twin barrel carb - sparking problems
Pages: [
1
Go Down
« previous
next »
Author
Topic: Flaminia V6 engine, single solex twin barrel carb - sparking problems (Read 1408 times)
FERGTS246
on:
14 August, 2021, 02:00:32 PM »
Hi All,
I’m having repeated problems with my engine not running properly.
I’ve had spark plugs stop working, sparks leaking through rubber plug caps and creating a tiny hole in them. I’ve replace the bad spark plugs and the rubber covers.
The engine runs great immediately afterwards but then a couple of days later, after driving the car couple of times for short distances, the engine runs badly again!
Now, in the order of the cylinder firing sequence, cylinders 3, 5 and 6 aren’t firing - (see diagram attached). I can tell because the exhaust manifold branches for these cylinders aren’t getting hot whilst the others are.
I’ve got:
‘Ignition123' Electric Distributor Ignition system
Carbon core HT leads
NGK iridium spark plugs (NGK BKR6EIX 6418 Spark Plug Iridium IX)
Standard spark plug rubber caps.
The position of the cylinders not firing don’t suggest a blocked carb main jet. I’ve had a problem with blocked fuel pipe and/or weak fuel pressure but I’m pretty sure that has been solved now.
Do you think its possible that 123 Ignition system, carbon core HT leads are damaging the spark plugs and rubber caps?
Any other suggestions please?
Non-firing-Cylinders-14Aug21.pdf
(353.71 KB - downloaded 64 times.)
bobhenry999
Re: Flaminia V6 engine, single solex twin barrel carb - sparking problems
Reply #1 on:
15 August, 2021, 05:13:47 PM »
Would it be worth changing the ignition system back to a points/condenser system and see if that cures the problem ?
If it does you can then make the electronic ignition the culprit.
Bob
Flavia 815 Vignale
Flavia 819 Milleotto
Flavia 815 Coupe Inezione
2000HF x2
2000 Coupe
2000 Sedan x3
FERGTS246
Reply #2 on:
17 August, 2021, 01:47:16 AM »
Hi Bob, Thanks for your reply. I'll try that as I've tried everything else.
I managed to get it running on all cylinders after de-carbing the plugs but it has now developed a back fire through the carb on tweaking the throttle. After checking for vacuum leaks, doing tappets, cleaning jets and checking float level its now not firing on one cylinder and still has a back fire even, though less often.
I'm wondering if the 123-Ignition electronic ignition dizzy and Bosch coil are just to strong for the plugs and/or HT leads and doing something to them that makes them stop working intermittantly and then eventually kills them?
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
Model Technical and Interest
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
