23 April, 2024, 12:59:17 PM *
Pages: 1 [2]   Go Down
Author Topic: 037 Outing  (Read 7496 times)
jus
« Reply #15 on: 15 May, 2022, 11:14:43 PM »
Hi all. A further update on the idle screw / jet situation on this car.
I had to replace the battery recently - which involved taking the carb and the carb to supercharger manifold off (they really buried the battery well on these), so I took the opportunity to take the carb apart again. I stripped it down and put it through the ultrasonic cleaner. On putting it back together, I noticed that the idle jets were different sizes - a 45 and a 55. Strange - because as far as I can see, the carb consists of two identical circuits.
Just to recap, when I first got this car it didn't idle too smoothly and adjusting the single idle screw didn't seem to make much difference. The idle oscillated at start up, and in general, the car idled, pulled off, cruised and generally ran better with with some choke even when fully warm. Couldn't find any vac leaks, electrics were fine, fuel delivery ok, so I focused on the carb. I got another idle adjust screw and fitted it late last year in place of the blanking cap that was installed where the 2nd idle screw should be. Installing and adjusting it didn't seem to make much difference.
So - as it was still generally 'better' during idle situations with the choke slightly open - I took that to mean that the idle circuit was running a bit lean. My plan was to try some larger idle jet sizes given modern fuel v. 80s 5 star.
The next phase was to get some pairs of jets - 50, 55, 60, 65 and 70. After making sure that the carb cleaning and rebuild hadn't improved things, I installed two 70 jets in place of the 45 and the 55. I thought it best to go straight for the largest ones to make any effect more obvious. I then had the potential to adjust from 0 up to 1.4mm (combined) of idle jet. So - it started up ok and ran after a bit of twiddling of the idle screws, but it had reverted back to the oscillating tickover (see previous posts). However - I've now found that if I screw both idle adjusters right in (but obviously not driving them hard into the end position), the car is happy under all conditions. It starts fine, doesn't oscillate to any real extent, doesn't stutter at cruising and has no flat spots. I'm pleased, but I'd like to understand why this setting seems to cure the issues.
Does the Beta VX have a similar Weber DCNVH carb fitted? If so - I wonder if it has one or two adjuster screws.
Thanks for any input,
Justin.
1969 S1 Fulvia 1.6
1971 Ex-works Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
Recently passed: 1986 Delta S4
Long since passed: Delta HF Turbo ie, Delta HF Turbo (carb), Delta 1500.
« Reply #16 on: 16 May, 2022, 09:03:16 AM »
Pretty sure the Beta VX cars had a 36DCA carburettor but my tinkering was almost 30 years ago now and I left it to Barry Waterhouse to modify the chokes on the engine he built for the Stratos replica. You may be able to research that carburettor's spec online?
« Reply #17 on: 16 May, 2022, 02:27:12 PM »
I can confirm my HPEVX carb has two idle screws. The car is new to me so only just starting to understand it. Run nice though with no issues.
jus
« Reply #18 on: 16 May, 2022, 02:42:33 PM »
Thanks Guy and Tim.
Any ideas as to why I'm seeing this kind of behaviour? (Directed to anyone reading).
Cheers,
Justin.
1969 S1 Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
Richard Fridd
« Reply #19 on: 16 May, 2022, 04:30:31 PM »
A bit like my Solex 40 PAAI then!
 Better with choke also, air leak at spindles or low fuel level in carburettor in my case I expect(standard jetting).  But one jet alteration seems to upset another.
Richard
jus
« Reply #20 on: 29 July, 2022, 07:31:07 PM »
So - today, I took the 037 to a rolling road. It's in a configuration where it has two idle (slow running) adjustment screws, both pretty much wound in (by me), to get the best overall running / starting & tickover that I could get.
The verdict was, that it was pretty much spot on - and no changes were made. The owner of the road confirmed that it should have two adjustment screws, which is what I changed it to a while ago - so that was good to know.
I've sent a mail over to Joe Macari to see if they have a picture of the carb on the car that they currently have for sale (or whether they could have a quick look) - but as predicted, no reply:
https://www.joemacari.com/stock/lancia-037-stradale/10004868
Looks quite nice in this colour - but I won't be changing...
1969 S1 Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
jus
« Reply #21 on: 29 July, 2022, 09:16:01 PM »
Hot off the press - I have a reply from Joe Macari (one of his guys anyway).
You can see a blanking screw in the form of a cap-head has been installed. So - one adjuster and one side is not adjustable and effectively fully open as a valve.
1969 S1 Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
Pages: 1 [2]   Go Up
Page created in 0.085 seconds with 21 queries.
