27 April, 2024, 12:38:36 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
, for Database Administrator e-mail
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Flavia
Lancia Flavia intermittent horn
Pages: [
1
Go Down
« previous
next »
Author
Topic: Lancia Flavia intermittent horn (Read 2911 times)
Angle Grinder
on:
28 April, 2021, 07:33:59 PM »
Reawakening my Flavia PF Coupe after a long hibernation. I have discovered that my horn only works when the steering wheel is in certain positions.
There is a large arc of movement where there is no power supply being transferred to the copper ring part of the steering wheel boss.
From looking at pictures on the interweb, I'm guessing that there is some sort of spring-loaded bush that should make an electrical contact with another copper ring that is mounted into the steering column which is in turn connected to a yellow positive feed wire.
Is this a problem that anyone else has encountered? Does the bush wear out or is it more likely to be dirt on the contact surfaces causing a poor connection?
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
msh2908
Re: Lancia Flavia intermittent horn
Reply #1 on:
29 April, 2021, 02:13:58 PM »
I had the very same issue with my Flavia Coupe 2000. To cure it I removed the steering wheel, the central boss and gave the electrical connections, which include apin type connection, a jolly good clean and hey presto it now works fine. All sorts of grub collects between the steering wheel and the boss. Make sure that you have the wheels centred before refitting the steering wheel or it will be wonky when you come to use it.
Hope this helps?
brian
Reply #2 on:
30 April, 2021, 08:00:54 PM »
I had a horn that sounded occasionally going over bumps and was temperamental so at the same time check the wire going through the column still has insulation.
Brian Hands
1922 Hands Tourer
1934 Augusta standard saloon
1938 Aprilia S1 saloon
1953 Aurelia B10
1965 Flavia Sport
Adamburton99
Reply #3 on:
16 July, 2021, 09:58:54 AM »
I've the same issue on my Coupe 2000, I'll follow the removal & cleaning advice- thank you!
Neil
Reply #4 on:
16 July, 2021, 04:41:03 PM »
Check the horn relay, I assume it will be similar to a Fulvia under the wing, mine was temperamental it might need the contacts a check/clean ip
Neil
386
1973 Fulvia S2 1.3
Angle Grinder
Reply #5 on:
17 July, 2021, 07:02:48 PM »
It was the bush that was the problem. Bought a substitute bush from Omicron. It's not the same as the original brass bush and =slops about a bit in t=its seating, but the horn now works so job done!
Previous cars:
1983 Prisma 1600
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
