26 April, 2024, 10:05:28 AM *
Author Topic: Lancia Fulvia coupe weather strip.  (Read 4769 times)
Sean.D
« on: 20 August, 2020, 04:40:40 PM »
Has anyone found a good solution to attaching the furry weather strips to the chrome trim?
I have taken the trim off and removed the old strip that was stapled on, but clearly a special tool and staples would be needed to attach this way.
The supplier gave me a couple of helpful suggestions, but thought I would see what success others have had with this task.
Any suggestions would be much appreciated.
Thanks in advance.
Sean
nthomas1
« Reply #1 on: 20 August, 2020, 05:04:04 PM »
Sean - It would be worth having a chat with Tony Jones.  I've got his contact details if you need them.  He's just fitted his using an adhesive - Delta Tru-Flex.  It's an adhesive he's been using for years in marine applications.  He drilled a lot of small holes to give plenty of grip for the adhesive.
I'm about to do mine and was planning to follow Tony's process. It will be interesting to see if anyone suggests other solutions.
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
Sean.D
« Reply #2 on: 20 August, 2020, 06:54:19 PM »
Hi Norm,
Yes, if you don't mind giving me Tony's contact details I will email him directly.
Many thanks
Sean
nthomas1
« Reply #3 on: 20 August, 2020, 07:05:42 PM »
I'll pm you Sean.
Norm Thomas
Own:
jimbo64
« Reply #4 on: 20 August, 2020, 07:48:23 PM »
I’ve just done mine using CT1 amazing stuff will stick anything to anything
Sean.D
« Reply #5 on: 21 August, 2020, 08:21:32 AM »
Ok thanks...looks like a good tape may be the way to go.
Much appreciated.
« Reply #6 on: 21 August, 2020, 11:18:47 AM »
I did mine 15 years ago using tiny countersunk stainless self tappers as this was advised by Omicron. The screws go deep into the “fur” so no danger of scratching the glass.
Sean.D
« Reply #7 on: 22 August, 2020, 08:43:24 AM »
Thanks Tim, yes advised the same.
Struggling to find such very small screws.
motoloco
« Reply #8 on: 25 August, 2020, 10:58:48 AM »
I’ve just done one door by remaking the staples from wire. A lot of effort and I’m not that happy with the result, so it would be good to know of a successful alternative.
« Reply #9 on: 25 August, 2020, 02:41:28 PM »
I sourced through a local fastner co. But I suspect you can buy on ebay after careful research (try Spalding Fastners - they have a huge range of stainless stuff).
Sean.D
« Reply #10 on: 25 August, 2020, 03:37:22 PM »
Thank you, I did eventually find some after a lot of online searching.
I will try the screws first and if no joy will go for the adhesive solution.
nthomas1
« Reply #11 on: 28 August, 2020, 05:57:45 PM »
Hi Sean - I decided to use adhesive plus 3 small screws each side to prevent any chance of "drift" over time.  I've just posted the approach I used on my "Slow Fulvia Rebuild" thread.
Norm Thomas
Own:
my69S1
« Reply #12 on: 29 August, 2020, 11:21:37 AM »
For those of us that have yet to tackle this chore, what size screws are being used?  Thanks.
OK.  Just found the measurements in Norm's thread.  Thanks.  Another source for these tiny screws is https://www.mcmaster.com/.
« Last Edit: 29 August, 2020, 11:32:16 AM by my69S1 » Logged
Justin McArdle
Fulvia Berlina 2C
« Reply #13 on: 29 August, 2020, 12:47:57 PM »
www.accu.co.uk are a UK good source
Lancia 2000 HF Coupe
Fulvia Berlina 2C
Sean.D
« Reply #14 on: 29 August, 2020, 02:42:01 PM »
Thanks Norm,
I've looked at your thread and appreciate the detail there.
I got hold of some 2.2*6.5mm screws through Bolt base on Amazon . (Very cheap)
However I need to drill some holes as they don't quite screw into the moulding as is...that was too much to hope for.
I think I will also go for the adhesive fix with some additional fixing screws but am concerned about damaging the trim.
Not had the chance to complete the task yet, I'll let you know how I get on.
Page created in 0.04 seconds with 21 queries.
