17 May, 2022, 07:55:58 AM *
Author Topic: Fulvia S1 Girling conversion  (Read 1809 times)
simonpen
« on: 03 August, 2020, 04:25:10 PM »
Rossocorsaitalia have a Girling (front) brake conversion kit for S1 Fulvias. Didn't think this was doable. Does anyone have any experience of it?
1969 Rallye 1.3S
« Reply #1 on: 03 August, 2020, 05:42:48 PM »
Why would you want to? Properly maintained there's nothing wrong with the Dunlop set up, I've been over the Pyrenees and the alps a number of times, and in 20 years I've never had a problem, certainly high pedal pressure is required, but they have excellent feel.
8227  Cool
« Reply #2 on: 03 August, 2020, 06:12:46 PM »
8227  Cool
I agree if the car is used regularly. If not then the Dunlops are more problematical but when used for 100 miles they are very good. The Girlings either work or seize up up depending on maintenance.
Jay
« Reply #3 on: 04 August, 2020, 12:30:09 PM »
Yes this can be done, it’s better if you use a S2 21mm master cylinder, the other issue is clearance on 13in rims. I am also looking at this plus adding a S2 servo, I mocked it up and seems to have enough room.
Julian Wood, Kingston, London
jus
« Reply #4 on: 04 August, 2020, 01:11:23 PM »
I think my S1 has this modification and it has 13" wheels.
I'll take some pics and try to upload them.
1969 S1 Fulvia 1.6HF Rallye
1982 Beta Spyder
1982 037 Rally #33
1986 Delta S4 #33
Justin McArdle
Fulvia Berlina 2C
« Reply #5 on: 04 August, 2020, 03:44:41 PM »
My Fulvia Berlina 2C has dunlop brakes (calipers recently replaced with new units) and non standard servo - see photo
Justin
Lancia 2000 HF Coupe
Fulvia Berlina 2C
ColinMarr
« Reply #6 on: 04 August, 2020, 09:36:01 PM »
Beware! The geometry of the brake and clutch pedal mountings on S1 cars is different to those of S2 and S3. If you try to fit an S2 master-cylinder and servo you need to make a serious modification to the spacer link tube that goes between the bulkhead and the servo. Somewhere I have drawings to show the critical angles and dimensions for cutting and welding. My advice is don’t do it – stay with Dunlop!
Colin
Jay
« Reply #7 on: 05 August, 2020, 02:39:56 PM »
What I have gathered is that replacing the master cylinder to a dia  21mm and front calipers is pretty much a direct swap and was done in period as the Girling have a much larger surface area. There is another forum where this conversion is well documented.
The adding of the servo was exercise that I wanted to see if I could solve, with it being reversible. So looking at the space and geometry it looks like it can be done, I will need to change the connecting rod where it meets the pedal and fabricate a mounting plate of the right depth, angle and from 2 to 4 bolts. The biggest issue is that it’s very close to the steering box.
simonpen
« Reply #8 on: 05 August, 2020, 03:45:57 PM »
Thanks for the replies. I shan't be going down this route as the Dunlop system in good nick is good enough and the conversion I saw is pricey. I have been told that the easiest way is to source a pair of S2 uprights and callipers. Not sure why one would bother with the extra hassle of fitting a servo although my S of course has a remote servo already but I'd be happy enough without servo assistance.
1969 Rallye 1.3S
Page created in 0.05 seconds with 20 queries.
