Author Topic: Parcel shelf string hooks..  (Read 5436 times)
Kevinlincs
  • Permanent resident
« on: 22 August, 2019, 08:23:14 PM »
Not sure if you guys noticed these on ebay, or even if you need any, but they are a great reproduction of the fragile hooks for the parcel shelf strings. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F273961614315
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Parcel shelf string hooks..
« Reply #1 on: 22 August, 2019, 08:34:36 PM »
Fitted mine tonight, makes a nice change to have the shelf lift up with the hatch!
They are a very good quality recreation, nice fitting in just the same way as the original.
Pictured is the original one still on the string with the new ones aside it.
Flavia 815 coupe
Delta integrale
Rob
  • Megaposter
« Reply #2 on: 02 September, 2019, 08:41:42 PM »
They look spot on Kev  ;). 3D printing is great for reproducing those small plastic parts that go brittle & snap over time. I've bought quite a few nylon clips & bushes from Shapeways which although quite expensive fit perfectly.
Rob MacFarlane
1988 Delta HF turbo ie
2000 Fiat Coupe 20v
1987 VW T25 Camper
grandespud
  • Lapsed
  • Member
« Reply #3 on: 10 May, 2021, 02:28:00 PM »
Hi All
Does anyone know if these are still available anywhere?
A1.6HPE
  • Senior Member
« Reply #4 on: 10 May, 2021, 03:24:28 PM »
Here is a listing for similar items, don't know if it is the same supplier as above, seems to be just the hook and the shroud is not included.
www.ebay.co.uk/itm/293571179779]http://www.ebay.co.uk/itm/293571179779]www.ebay.co.uk/itm/293571179779
Leo
Edinburgh Regional Co-Ordinator
grandespud
  • Lapsed
  • Member
« Reply #5 on: 10 May, 2021, 07:41:24 PM »
Thanks Leo. It's a start, but I do need the outer casing for both sides as well. The hooks and strings are non-existent on mine!
