26 April, 2024, 07:40:32 PM *
Author Topic: Electrolysis rust removal  (Read 2926 times)
Kevinlincs
« on: 16 June, 2018, 06:28:59 PM »
Thought I'd share this simple yet very effective method of rust removal that requires very little in the way of equipment.
Sure, you can buy a blast cabinet and get stuff clean but they aren't the cheapest way to do it plus take up a lot of room and you need a compressor with a good CFM specification to run it.
For electrolysis all you need is a battery charger, a plastic bucket and some odds and ends.
I use it when grinders of wire wheels, knotted or otherwise, won't remove the rust and the piece is small enough..it's handy for delicate parts too as there is no chance of deformation or damage, all you remove is rust.
My homemade bucket is just that, has 4 "legs" which are connected in series around the perimeter which you connect the battery charger positive to,  the negative goes on the piece to be cleaned via a metal bracket, making sure you don't touch the legs to it! The water solution is just water with soda crystals in..
Better described here...plenty of differing descriptions on the web and youtube etc
http://antique-engines.com/electrol.asp
Flavia 815 coupe
Dedra turbo
Delta integrale
Kevinlincs
« Reply #1 on: 16 June, 2018, 06:30:39 PM »
This afternoon I've been doing the top spring pans for my integrale, the one on the left has been cleaned and cleaned as much as it could be with a knotted wheel on a 4" grinder, the rust is solidly on and would require sandblasting to get any more off.
Flavia 815 coupe
Dedra turbo
Delta integrale
Kevinlincs
« Reply #2 on: 16 June, 2018, 06:31:40 PM »
As you can see, all the rust comes off and leaves purely solid metal, no rust left at all.
Be sure to paint it quick though!
Flavia 815 coupe
Dedra turbo
Delta integrale
« Reply #3 on: 17 June, 2018, 09:22:12 PM »
This was a good series I made my daughter sit through:
https://www.youtube.com/watch?v=sIAi1M9X8s8&t=220s
Kevinlincs
« Reply #4 on: 18 June, 2018, 07:15:42 PM »
Now She explains it better than I ever could!
And She actually knows how it does it rather than me thinking it's witchcraft  Grin
She'd be handy to have around the workshop, happy as Larry cleaning bits up!
Flavia 815 coupe
Dedra turbo
Delta integrale
Page created in 0.052 seconds with 21 queries.
