11 April, 2021, 03:47:52 AM *
Pages: 1 ... 6 7 8 9 10 [11]   Go Down
Author Topic: E55 LBR the parallel project  (Read 18485 times)
« Reply #150 on: 06 April, 2021, 11:05:38 AM »
The beast is bolted to the bench so it won't fall over...managed to do 2 rear and one front bearing on the Suzuki but really need a slide hammer to get the front hub off as the outer race stays onto the hub when you finally get it off. The race is now stuck on the hub and Suzuki list a special puller but Youtube came to the rescue. As the race is no longer needed because the new bearings come as a complete unit the race is no lnger needed so a kind man on Youtube showed a method of grinding an X into the race and bashing out a V shaped bit that releases the grip of the race on the hub and with a bit more bashing it was off with no damage to the hub. So we powered up the compressor and gave the 3.5" saw thing a try out and 10 minutes later it was off Amazing!
Thing is the gearchange on the Y10 is next to unuseable so I need to put some new bushes in (using the new toy) so do the Fiat Panda ones fit? vaguely remember Ed China changing some on a Panda...
Clarkey
While all the bushes will probably need replacing, the most wear is in a bracket/swivel tree bearings and shaft that bolts to the back of the gearbox, not sure if these still a available but I think I still have the exploded drawing and the part numbers of the bits involved,from when I did my Y10 Gtie about 15 years ago!
1999 Suzuki Wagon R+ GL, now my daughters
« Reply #151 on: 06 April, 2021, 12:15:05 PM »
It might be worth checking on E-per to see if Cinquecento bits will do.
Kevinlincs
« Reply #152 on: 06 April, 2021, 09:22:58 PM »
Found some of these for sale somewhere last year, I'll try and find where.
On my Y10 LX they were OK so I didn't bother buying, but it was the complete bracket with the new link installed.
Kevinlincs
« Reply #153 on: 06 April, 2021, 09:38:03 PM »
This is the main piece that bolts to the back of the gearbox, if there's a lot of wear in the bushes it will ruin the accuracy of the change.
https://www.ebay.co.uk/itm/Fiat-Panda-One-Y10-Support-Drive-Gears-91385328-7691320-7652856-VEMA-13229/133708120948?hash=item1f21a00374:g:E~EAAOSwIFBfl70V
« Reply #154 on: 07 April, 2021, 07:26:20 AM »
That's the one!
lancianut666
Slow but rough
« Reply #155 on: 07 April, 2021, 08:25:33 AM »
Overwhelmed by all the help and support thanks guys
Clarkey
Kevinlincs
« Reply #156 on: 07 April, 2021, 10:17:48 PM »
Also I now recall there being two types, there was another one that looked nigh on identical but on inspection the bolt holes were in different places, both in-line from memory rather than offset as per this one, so worth checking..
Kevinlincs
« Reply #157 on: 07 April, 2021, 10:33:36 PM »
Slightly similar.....
https://www.ebay.co.uk/itm/13220-Support-Drive-Complete-Box-Gears-Fiat-Panda-750-900-1000-1100-86-97/373100839257?epid=5025028886&hash=item56de8b0159:g:zNUAAOSwd4pe~JaF
lancianut666
Slow but rough
« Reply #158 on: 08 April, 2021, 08:30:24 AM »
Thanks again for all the help It seems I will have to check out what is fitted and take it from there.
Clarkey
lancianut666
Slow but rough
« Reply #159 on: 08 April, 2021, 03:03:33 PM »
Hi all
Had a quick scrummage under the car at the gearchange and low and behold the gizmo bolted to the gearbox was really loose...so out with a 13mm socket and all tightened up thing was the change still seemed remarkably vague as before Huh? so will have to get the car up in the air a bit so I can get underneath properly and have a good rive about with the linkage. Another point is from my limited view of the bracket fixing holes they look to be in line and not diagonal as in the link Kevin put up...Was hoping to give the little beast a few laps of the carpark so will try and get the linkage sorted before that.
Clarkey
lancianut666
Slow but rough
« Reply #160 on: Yesterday at 10:54:27 AM »
Whilst trawling ebay for linkage parts came across this https://www.ebay.co.uk/itm/Set-Hebelwirkung-Austausch-Fiat-Panda-Lancia-Y10-Fur-7687667-4259848/183730938203
It seems to be a kit to replace the bushes in the gear linkage but what are the roller bearings for?
Puzzled of Redcar
« Reply #161 on: Yesterday at 07:23:09 PM »
From the exploded diagram in the listing I think they are for the front end of the rods from the gear lever to the bell cranks on the gear box. That diagram says 1988 to 1992 but the application check comes up positive for a 1985 Fire.
Pages: 1 ... 6 7 8 9 10 [11]   Go Up
Page created in 0.07 seconds with 21 queries.
