23 May, 2024, 02:32:12 PM *
Pages: 1 ... 13 14 15 16 17 [18]   Go Down
Author Topic: E55 LBR the parallel project  (Read 84473 times)
lancianut666
Slow but rough
« Reply #255 on: 19 May, 2024, 02:02:30 PM »
Finally found that receipt and swapped the plugs for the correct ones put them in and the little monkey started with out even having to charge the battery...the petrol is months old so the theory about the plugs might be true.
As the Y10 has been neglected a bit lately I treated it to a set of chrome locking wheel bolts.
Clarkey
« Reply #256 on: 21 May, 2024, 11:09:16 AM »
on the subject of not keeping fuel in your classic this may be ok if it is sufficiently  modern to have a plastic tank, but it is asking for trouble if it is a steel  tank. Steel rusts (just peer into any steel tank) in contact with moisture laden air (typical conditions for storage from autumn to spring), this leading to rust  getting into the fuel system blocking jets etc and rotting out the top of fuel tanks. I have always put my cars away with a full tank (near as dammit) when I am not using it. Never had any running problems 6 months later.
Tim,
I've always used E5 in 'Fay' without any additive since we were first forced to use it.
I now use the latest E5 98/99 octane and I'll never use E10.
The pre E10 E5 was never a problem , but we're now told petrol goes 'off"  and won't keep, but does this also apply to E5 now? as I usually keep the tank full over winter as well.
lancianut666
Slow but rough
« Reply #257 on: 21 May, 2024, 04:37:17 PM »
I must admit I was surprised how easily it started and even ran briefly with no choke despite not being fully warmed up. The weather has socked in again up here as I was going to treat it to some lead additive and a fresh gallon of petrol and give it a 10 lap blast round the units so it will have to wait. I will have to resist giving it too much choke next time out and keep those plugs happy. Not so sure about the shelf life of E5 petrol but it does seem to last a bit longer than has been known in the past.
Clarkey
« Reply #258 on: Yesterday at 12:02:56 PM »
I've never used lead additive in my Y10 in 16 years and 60k miles. I always use E5 which at the local Esso station is zero methanol.
I like your wheel nuts. Can you share the specification and where you got them as I could do with a set.
lancianut666
Slow but rough
« Reply #259 on: Yesterday at 01:19:21 PM »
Hi Frank
I think I will try a 'branded' petrol and see if it is any better than the supermarket stuff.
The nuts came from here https://www.ebay.co.uk/itm/155903460603
I emailed them first to check if they would be OK with the factory wheels and he assured me they would be.
Clarkey
« Reply #260 on: Today at 10:29:21 AM »
Thanks for the wheel nut info.
There's all sorts of things on fuel. Tesco that I use are contracted to Esso so Tesco fuel seems to be "branded" fuel anyway. It is said that all fuel is the same ex refinery and the brands just put their own additives in before delivery to the petrol station. I'm presuming the ethanol for E5 and E10 petrol is one of those additives. E5 and E10 of course mean "no more than" 5% or 10% ethanol. I'm also told there is variation according to which refinery it comes from with my local Esso E5 being 0% ethanol. There must be lots of research one can do but people seem to speak well of Shell's premium offer and poorly of Morrisons super market fuel.
Neil
« Reply #261 on: Today at 10:53:05 AM »
Last year Esso advised around August/September time their marked E5 had 0% ethanol would now contain some to a maximum of 5% added, the 0% ethanol era added has now ended. May be some areas can still get 0% added?   The different suppliers add their own brand of additives, the basic fuel from the refinery is the same across the UK, Esso, BP and Shell probably have better additives and detergents than the supermarkets is the commonly held view.
'We currently supply an ethanol-free Synergy Supreme+ 99 unleaded in some parts of the UK. From September 2023 our Synergy Supreme+ 99 will transition to contain up to a maximum of 5% ethanol at all Esso pumps irrespective of which part of the country they are located. The labelling at our pumps will remain as E5 for Synergy Supreme+ 99 unleaded'
« Last Edit: Today at 10:58:54 AM by Neil » Logged
Neil
386
1973 Fulvia S2 1.3
Pages: 1 ... 13 14 15 16 17 [18]   Go Up
Page created in 0.051 seconds with 21 queries.
